Thread: LT1 wont start
    Awesome member Bad Co.'s Avatar
    Aug 2009
    Green
    1994 Z28
    LT1 wont start
    I just pulled the intake saturday to replace the gasket. I just got everything back together today. The motor turns over but wont fire off. When you turn the key you can hear the pump kick in. I went as far as changing the coil out. Still the same thing. Any ideas?
    plug everything back in???
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    damn optispark...
    Aug 2009
    Green
    1994 Z28
    everything is plugged back in. injectors, etc. i checked and rechecked. I hope its not the opti. i replaced it 2 months ago with the gmpp opti. My mechanic done that. I know it getting spark but i cant tell if its getting fuel. i pulled a spark plug on the head and put a screwdriver to and had a decent lil spark. Im thinking it a fuel issue.
    Quote Originally Posted by Bad Co. View Post
    fuel pressure guage... $4.00 at a parts store... but most of the time it's the damned optijunk... bad set up where colant leaks into/on to it...
    Oct 2009
    pewter
    99 trans am
    did you prime the fuel lines before trying to start it? and bleed the air out?
    Aug 2009
    Green
    1994 Z28
    I was told you didnt have to prime the fuel system. I changed out the fuel filter today and still nothing. It looks like im headed to the shop tomorrow.
    old timer blue02Z's Avatar
    2002 Z28
    hmmmmm. get a spark tester to be sure you have a good strong spark. old school ways using a screwdriver can give eh results. get a fuel pressure gauge. remember you need pressure and volume
    Aug 2009
    Green
    1994 Z28
    when i pulled the filter i turned the key to make sure there was fuel coming from the pump. It shot out significantly. To see if i was getting spark, while my wife was cranking the car i shot a lil wd40 through the throttle body to see if it would try to turn over and i got nothing. So now i think i got a spark issue. im still going to get a fuel pressure gauge just to see where im at. But for what its worth, when i pulled the fuel rail i was kinda careless with the fuel rail and layed it upside down on the side of the car while i made the repair. i wonder if i ruined the pressure regulator diaphram by doing that?
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 09:54 PM
  2. Z71 wont start
    By duranws6 in forum General Help
    Last Post: 01-09-2013, 08:49 PM
  3. LT1 wont start
    By Bad Co. in forum LT1
    Last Post: 11-16-2010, 06:32 PM
  4. ls1 wont start
    By FutureWS6 in forum General Help
    Last Post: 07-02-2010, 09:07 PM
  5. car wont start
    By redss2000 in forum General Help
    Last Post: 06-20-2008, 02:06 PM
