Thread: Z71 wont start
01-09-2013, 05:49 PM #1Junior Member
- Dec 2012
- Tn
pewter- 2001 ws6 1994 z28
Z71 wont start
Ok guys i know this isnt a ls engine but i have a 98 z71 i traded for relplaced intake gaskets in ran before hand...got dun with it all went to start it up it ran rough mssed with it a few days then it got were it wouldnt start at all....i have replaced the fuel regulator fuel pump holds 55 lbs and im geting fire if i pour a bit of gas in throttle body it fires right up ..im not geting fuel for some reason im geting 12 volts to the wires that go to the top of my spider injector system ..also have a new crank sensor any ideas guys or anything i might have missed
01-09-2013, 06:16 PM #2
Have you ensured that the intake is torqued down to the proper spec and there are no large vacuum leaks? There was another member here who just ran into a similar problem and went through days and days of headaches trying to figure out what his issue was, and when he tore it down again he found a 8mm socket in there
01-09-2013, 06:21 PM #3Junior Member
- Dec 2012
- Tn
I just dont think im geting fuel because i can undo my number 1 plug wire and turn the truck over for about 30 secs and there wont be a drop of gas or cant even smell gas on the plug
01-09-2013, 07:12 PM #4
have you looked inside the intake to see if that spider is leaking? The intake will be washed down with fuel if it is. What engine is this....5.7? It sounds like you've already done my first thought. I had a 98 4.3L that was doing the same thing.....ended up being the fuel pump. It was only off 2-3lb's but it was enough to keep it from starting. Did you go back over your install and make sure everything is hooked up correctly and there are no issues with the install? 9 out of 10 times if something was running prior to working on it then it's a mistake made when putting it back together.
01-09-2013, 07:49 PM #5Junior Member
- Dec 2012
- Tn
Yea its the 5.7 I guess 55 lbs is enough for it to crank I dont really know for sure and the spider aint leaking any
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
LT1 wont start
By Bad Co. in forum General HelpReplies: 8Last Post: 11-18-2010, 07:23 AM -
LT1 wont start
By Bad Co. in forum LT1Replies: 0Last Post: 11-16-2010, 05:32 PM -
ls1 wont start
By FutureWS6 in forum General HelpReplies: 4Last Post: 07-02-2010, 08:07 PM -
car wont start
By redss2000 in forum General HelpReplies: 12Last Post: 06-20-2008, 01:06 PM
