Results 1 to 13 of 13
Thread: car wont start
06-18-2008, 07:37 PM #1
car wont start
This has happened 4 times now..., Basicly the car acts as if the clutch isnt pushed in, everything it lit on dash. I just keep tryin it and eventually it finally will crank and it fires right up.
I assume something to do with the sensor that tells the car i have the clutch in? Is this normal?
I have a warnenty still until aug so if i could get it coverd it would be great...
This prob wouldnt mean my clutch is gone would it? because it seems to work fine
06-18-2008, 07:48 PM #2
that switch is on the back of the clutch pedal if that's what it is.
06-18-2008, 07:49 PM #3
does your security light stay on or anything like that? What happens when you turn the key over? Nothing?
06-18-2008, 07:55 PM #4
all the lights go out i think,not sure if they come bck on or not until i let the key back? i just keep pushing the clutch back in and turning key till it cranks
06-18-2008, 07:58 PM #5
is this switch directly on the back of the pedal, i looked for it the first time this happened and i didnt see anything
06-18-2008, 08:18 PM #6
You have to take out the bottom plastic panel and knee bolster to get to the switch. It's a white pushbutton switch you'll see it. When you crank the engine see if the security light stays on. If it does, it's the resistor on your key
06-19-2008, 04:45 AM #7
06-19-2008, 06:19 AM #8
well it not the key, ill have to take the underdash apart this weekend, you think i just reattach the sensor, or replace it?
06-19-2008, 07:10 AM #9
it's hard to say cause it could be the wiring to the switch. Check everything, make sure you have power and ground to the switch. Last resort, replace it if nothing else
06-19-2008, 08:31 AM #10
- Apr 2008
- Mississauga, Ontario, Canada
Black- 2002 Camaro SS M6
if nothing happens, and the lights just turn on but engine doesnt crank i would put my money on the security system our cars have. if its not the key it could be a corroded or loose wire under dash. i had the same stupid problem with my 95 bird. it was just a loose wire with the security system.
06-20-2008, 09:09 AM #11
06-20-2008, 10:20 AM #12
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
corroded/bad connection at the starter?
06-20-2008, 01:06 PM #13
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Z71 wont start
By duranws6 in forum General HelpReplies: 4Last Post: 01-09-2013, 07:49 PM -
LT1 wont start
By Bad Co. in forum General HelpReplies: 8Last Post: 11-18-2010, 07:23 AM -
LT1 wont start
By Bad Co. in forum LT1Replies: 0Last Post: 11-16-2010, 05:32 PM -
ls1 wont start
By FutureWS6 in forum General HelpReplies: 4Last Post: 07-02-2010, 08:07 PM
