    man_of_steel83
    Guest
    I need help with a noise on the car
    alright guys,
    this afternoon i heard a noise from my rear wheels, i figured it has something to do with the brakes. cause when your coming to a stop, it goes away while braking, then it comes back. Its the same sounds as to when you have a nail in your tire, then you take it out, the sounds as if air is leaking. at first i thought it was that of a air leak but im sure it something with the brakes. for the record My dash cluster stayed clean, i had no lights come on.
    Later that night i drove the car again after it sitting there for 3 or 4 hours and it went away. and input as to what that car was doing would be great
    man_of_steel83
    Guest
    Nobody has any ideas?
    Tulsa,OK
    Quick Silver
    2002 Z06
    Well I'm unsure why the brakes would affect it. However, I have noticed after a long drive my car has made me franticly look for a tire leak to find out it is some sort of hissing noise in back. I'm assuming its the fuel pump, not sure if is just sucking that much air in as the gas is getting pumped out or not.
    Thats my take though..
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    SATX
    2000 Trans Am
    fuel pumps hum, if something is hissing its porably an air leak, could be your bearings.
    man_of_steel83
    Guest
    the weird thing is that it did it for two days, and it hasn't done it since.
  1. LS1 noise?
    By rafael707 in forum General Help
    Last Post: 06-28-2012, 07:58 PM
  2. noise
    By texas twister in forum Automatic Transmission
    Last Post: 03-21-2009, 04:44 PM
  3. '01 M6 Noise
    By T/Aboo in forum Manual Transmission
    Last Post: 10-09-2007, 04:49 AM
  4. Noise that I can't get rid of!!!!
    By SilentStriker07 in forum Suspension and Handling
    Last Post: 02-14-2007, 07:58 AM
  5. Bad Noise.
    By csess in forum Firebird / WS6
    Last Post: 02-11-2007, 05:30 PM
