Thread: '01 M6 Noise
    New Orleans, LA
    '01 Trans Am WS.6
    Question '01 M6 Noise
    I thought I had a U joint going bad and checked the front and rear only to find that the tail shaft of the tranny had a good bit of play in it. Looks like it could be a bad bearing. Does anyone know if this is something common?
    T56 building fool thesource's Avatar
    San Antonio
    Multi colored
    89 coupe
    Its very unlikely that a bearing is bad but not impossible at all . The play in the tailhousing is probably from a worn yoke and rear tailhousing bushing . Does it leak from the rear seal at all ?
    New Orleans, LA
    '01 Trans Am WS.6
    No, it doesn't leak any fluid. It just has a good bit of play; enough to easily see... maybe a 1/16" or so.
    San Antonio
    Multi colored
    89 coupe
    It might have some wear in it but there's not a whole lot you can do about it . As long as its not leaking and not vibrating , you should be ok .
    New Orleans, LA
    '01 Trans Am WS.6
    The vibration is what made me initially suspect I had a bad U-joint. It does have a vibration that's noticable at around 70 mph.
  1. LS1 noise?
    By rafael707 in forum General Help
    Last Post: 06-28-2012, 07:58 PM
  2. Help: Help with noise!
    By 2001blackz28 in forum Camaro / SS
    Last Post: 04-16-2009, 03:03 PM
  3. noise
    By texas twister in forum Automatic Transmission
    Last Post: 03-21-2009, 04:44 PM
  4. Noise that I can't get rid of!!!!
    By SilentStriker07 in forum Suspension and Handling
    Last Post: 02-14-2007, 07:58 AM
  5. Bad Noise.
    By csess in forum Firebird / WS6
    Last Post: 02-11-2007, 05:30 PM
