Results 1 to 2 of 2
    Junior Member SilentStriker07's Avatar
    Feb 2007
    Ky
    Dark Blue
    2002 WS6 Trans-Am
    Noise that I can't get rid of!!!!
    Alright I have had this noise comming from my right rear for a few months now. When I'm going down the road its a chirping sound (Did not matter if I was going straight or turning either way), and when I put the brakes on it goes away.
    I had the wheel bearing changed and before that the rotors turned. Both times I asked if the suspension (mainly shocks) look ok and and every time the mechanic says they do. Well I have replaced the rotors and pads.
    Now the noise is only there when I turn left. Its not as bad but still there and a constant annoyance. Everytime either when the mechanic messed with it, it seemed to help but the noise was still there. I changed the rotors and pads and now its just when i turn left. Has anyone had this little noise demon? Ive put alot of money and been banging my head.
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    Make sure to lube all the caliper locations because they will move when the brakes are not applied and "chirp" because it is metal on metal. This is where the pads sit and where the caliper sits in the bracket.
  1. LS1 noise?
    By rafael707 in forum General Help
    Last Post: 06-28-2012, 07:58 PM
  2. Help: Help with noise!
    By 2001blackz28 in forum Camaro / SS
    Last Post: 04-16-2009, 03:03 PM
  3. noise
    By texas twister in forum Automatic Transmission
    Last Post: 03-21-2009, 04:44 PM
  4. '01 M6 Noise
    By T/Aboo in forum Manual Transmission
    Last Post: 10-09-2007, 04:49 AM
  5. Bad Noise.
    By csess in forum Firebird / WS6
    Last Post: 02-11-2007, 05:30 PM
