Thread: LS1 noise?
    Apr 2012
    vallejo,CA
    2000 camaro z28
    LS1 noise?
    just bought this camaro 2000, and wondering if this engine sounds normal? it has 105k on it.
    my first oil change i noticed really fine grey colored metal flake on my oil plug magnet enough to cover my pinky finger nail completely, so i flushed the system with cheap shell oil now all the flake gone, and now im using 10w40 valvoline HM + lucas additive.
    Apr 2012
    virginia
    blue
    2001 trans am
    m6 or auto, if its m6 could be pushrods, mine sounds similar though has sense i bought it, never skipped a beat. i used some marvel mystery oil in my crank it seemed to help.
    Apr 2012
    fort myers florida
    Are their any mods to the car? She does have a tap to her. Does she vibrate at all?
    Sent from my DROID BIONIC using Tapatalk 2
    top sounds normal to me but I'm hearing it through computer speakers. A little tapping noise kinda like a sewing machine is normal for LS1's. It could be a slightly bent rod if the previous owner dogged it out with too man high revs.
    Bottom side of the car - It's hard to tell, sounds like a clogged CAT to exhaust leak. Like I said hard to hear it
    When you rev up does it get louder? stronger?
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Hard to tell. you may have worn some of the lead off one of the bearings. Could be a worn main or rod bearing. I hope I'm wrong.
    Junior Member tdevil55's Avatar
    Nov 2009
    Hampton VA
    Navy Blue Metalic
    02 Z28 Camaro
    Could be a exhaust leak, bent push rod, or broken spring, hard to tell listening to is from a video.
    02 Z28/LS1 NBM - TIN CAN RACING
    Full bolt on, weight reduction mods, dyno tuned by FROST = 330hp/342tq New PB = 12.74 @109
    Apr 2012
    vallejo,CA
    2000 camaro z28
    Quote Originally Posted by lipsasaurus View Post
    M6, how much marvel oil you use?
    Apr 2012
    vallejo,CA
    2000 camaro z28
    Quote Originally Posted by Dsmdave View Post
    my car is stock, i might have flow masters, my headers are stock. i do have a fuel pressure unit that connects to my fuel rail, i dont know why the previous owners had that for...
    Apr 2012
    vallejo,CA
    2000 camaro z28
    i recently put a exhaust bandaide for the leak, and for the most part there is no exhaust leak, i need to upload another video showing it
    - - - Updated - - -
    thanks everyone for the input, i deeply appreciate it, i will try to upload a more hi-def vid sooon..
    Apr 2012
    virginia
    blue
    2001 trans am
    in oil i use 1 qt in place of oil like it says, in gas, i usually put X2 the dose the first time then 1.5X at each fill up. Oh i did upload a video of mine a while back, its on a thread here mine was mainly an exhaust leak it stopped after my LT header install, maybe its just fate saying you need headers.
    Apr 2012
    vallejo,CA
    2000 camaro z28
    will the MMO thin out my 10W40? the reason i use that weight is because it seems to keep my pressure up. When my engine is fully warm, 5w30 would make my oil pressure sit at 20psi at idle and up to 40-50psi when i step on the gas.. temperature where im at is about 65-86 degrees so its pretty warm.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    Did you find out what the noise was or are you still working on it ?
  1. Help: Help with noise!
    By 2001blackz28 in forum Camaro / SS
    Last Post: 04-16-2009, 03:03 PM
  2. noise
    By texas twister in forum Automatic Transmission
    Last Post: 03-21-2009, 04:44 PM
  3. '01 M6 Noise
    By T/Aboo in forum Manual Transmission
    Last Post: 10-09-2007, 04:49 AM
  4. Noise that I can't get rid of!!!!
    By SilentStriker07 in forum Suspension and Handling
    Last Post: 02-14-2007, 07:58 AM
  5. Bad Noise.
    By csess in forum Firebird / WS6
    Last Post: 02-11-2007, 05:30 PM
