Thread: cam position sensor
02-20-2008, 06:00 AM #1Junior Member
- Oct 2006
- huntsville
black- 1959 Apache
cam position sensor
OK guys. Need some real help here. I am building a custom ECU that will interface with the stock crankshaft and camshaft potion sensors for timing. The ECU is designed for the 24 tooth LS1 style crankshaft and 1X (rear) cam sensors. I understand that the LS2, LS3, etc. sensors have a 58 tooth crankshaft and 4X cam (front) sensors. Please let me know if I am incorrect on this.
What I am doing is building an LS3 equivalent engine from scratch, so I can put any parts in it I want. I know I can get crankshfats with the 24 tooth reluctor wheel, but can I use old LS1 hardware for the camshaft and sensor and it bolt right up to the LS3 block like if it were an LS1 so that it sends the signals I need to the ECU? I don't think the LS3 stock cam signal behaves the same as the LS1.
Any direction would be appreciated.
Thanks.
02-20-2008, 03:14 PM #2
well i never have worked on the ls3 but as long as you have the right reluctor you should be good
02-20-2008, 04:47 PM #3Junior Member
- Oct 2006
- huntsville
black- 1959 Apache
From what I understand, the "reluctors" are in different places and the sensors in different places. The LS1 has the sensor on the rear of the block and the "reluctor" is just a machined area of the cam that has a high spot and a low spot. For an LS2 or LS3 engine, the cam sensor is located at the front of the engine and the "reluctor" is simply a part of the cam sprocket with raised areas to give it a 4X signal.
I was just wondering if there is either a provision on an LS2 or LS3 block so that you could put an LS1 cam and LS1 sensor at the rear to get the signal I need, or possibly a sprocket that simply sends a 1X signal instead of the 4X signal so that I could use the front sensor.
Thanks.
02-20-2008, 05:47 PM #4Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
sounds like a pluasible (sp?) idea...
Question: Bad throttle position sensor?
By clg82 in forum Firebird / WS6Replies: 7Last Post: 07-29-2010, 12:10 PM -
cam position sensor replacement?
By PAT-LS101 in forum General HelpReplies: 8Last Post: 01-27-2009, 07:09 PM -
By dpinson in forum NitrousReplies: 6Last Post: 09-24-2007, 01:22 AM -
Cam Position Sensor Ground
By SStriker in forum General HelpReplies: 2Last Post: 09-13-2007, 07:54 PM -
Crankshaft position sensor help
By landon00 in forum General HelpReplies: 2Last Post: 02-20-2006, 07:10 PM
