Thread: Bad throttle position sensor?
07-29-2010, 11:34 AM #1
Hey everyone as some of you know last week I threw a SES light and cleaned the maf and it took care of it.....Now this morning I turn the car on and it starts to idle really high, when i shifted it into reverse it made a clunk (rpm's too high) then I go to put it into drive (A4) and it clunks again because the rpm's are too high, I am not throwing anymore SES light.......could it be a bad throttle positioning sensor? or something else?
suggestions please...
07-29-2010, 11:53 AM #2
07-29-2010, 11:58 AM #3Senior Member
- Nov 2006
- Indianapolis
Did you mess up the cable going to the TB? (not allowing it to close fully)
07-29-2010, 11:59 AM #4
07-29-2010, 11:59 AM #5
07-29-2010, 12:06 PM #6Senior Member
- Nov 2006
- Indianapolis
What about the PCV hose near that area where you were working. They are known to go bad there, if it was almost gone, then you touched it, that could've killed it. That would cause a high idle, a vacuum leak.
07-29-2010, 12:09 PM #7
07-29-2010, 12:10 PM #8Senior Member
- Nov 2006
- Indianapolis
^^^yes.
Question: Need to change Throttle Position Sensor
By LS1BL in forum General HelpReplies: 13Last Post: 02-20-2013, 12:02 PM -
Help: Installing a throttle position sensor
By 454transam in forum External EngineReplies: 4Last Post: 06-02-2010, 11:43 PM -
Throttle Position Sensor Voltage
By SilverFish in forum General HelpReplies: 1Last Post: 08-30-2008, 12:33 PM -
Fuel Problem and Throttle Position Sensor??
By GottaHaveLS1 in forum General HelpReplies: 1Last Post: 07-23-2008, 02:42 PM -
By dpinson in forum NitrousReplies: 6Last Post: 09-24-2007, 01:22 AM
