Results 1 to 14 of 14
    Junior Member LS1BL's Avatar
    Sep 2010
    NC
    Need to change Throttle Position Sensor
    I have never even heard of this sensor before. Where would I find it? Is there a write-up on this anywhere?
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    It's on the throttle body I believe it is the bottom one. It's not hard to remove it all you do is unscrew the screws attached to it and it comes right off.
    Pittsburgh
    2008 Hummer H3
    The TPS is usually located @ the opposite end of the throttle/butterfly shaft.. On one side you have your throttle linkages and on the other end the TPS.. It usually has a couple or so screws holding it in and has a round plug and connector.. Should look somewhat like the gray (top) sensor in this custom TB pic..
    Sep 2010
    NC
    sweet I appreciate it lots guys.
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by LS1BL View Post
    No prob.. But how do you know it's bad? Are you getting a code(ses light) for it?
    Sep 2010
    NC
    Ya i took it to auto zone and thats the code it was throwing.
    Apr 2010
    Alabama
    Black/ Silver
    I would make sure that it's plugged in correctly first before you buy another one. I also heard that the code can be thrown if the sensor is dirty or the throttle body is, so you might try cleaning them with tb cleaner. I don't know how true that is but it couldn't hurt.
    Sep 2010
    NC
    Quote Originally Posted by 98TransAmWs-6 View Post
    10 4 ill give it a shot. preciate it man
    Member mikey gavin's Avatar
    Oct 2010
    bruce
    bright red
    1998 formula trans am m6,
    is there a way to check it by unplugging it when its running
    Pittsburgh
    2008 Hummer H3
    For all the more a TPS costs I would just replace it..
    I also would'nt unplug it while it's running..
    Oct 2010
    bruce
    bright red
    yeah i guess so
    Orlando, FL
    Mean Black
    make sure you clean the throttle body. Sometimes carbon build up causes issues too.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    I agree, electrical components go bad after sometime. If it was a $200 part, I might have a different POV.
    Feb 2013
    Metairie La
    2006 hummer H3
    Hello Smittro for some reason the pics you have posted have been removed. I have a 2006 H3 hummer and i need to change the throttle position sensor and i am unable to locate anything online that shows me what it is. Is there any way you could put those pictures up? Thank you
  1. Question: Bad throttle position sensor?
    By clg82 in forum Firebird / WS6
    Last Post: 07-29-2010, 12:10 PM
  2. Help: Installing a throttle position sensor
    By 454transam in forum External Engine
    Last Post: 06-02-2010, 11:43 PM
  3. Throttle Position Sensor Voltage
    By SilverFish in forum General Help
    Last Post: 08-30-2008, 12:33 PM
  4. Fuel Problem and Throttle Position Sensor??
    By GottaHaveLS1 in forum General Help
    Last Post: 07-23-2008, 02:42 PM
  5. throttle position sensor
    By dpinson in forum Nitrous
    Last Post: 09-24-2007, 01:22 AM
