06-02-2010, 02:08 PM #1
Installing a throttle position sensor
Any one know how to install a throttle position sensor on a 1994 Trans am?
I took the old one off yesterday & installed the new one last night, but I am having problems.
I installed the new one last night, after cranked it started idling at 1500 rpm, & after giving it some throttle, it jumps up to 2000 rpm, & stays. I usually have the t/a idled at 700-800 rpm.
Any one might know what the problem is? Or have i done something wrong while installing for it to jump to such a higher rpm?
06-02-2010, 04:42 PM #2Junior Member
- Jul 2007
- Maryland
did you unhook the sensor then turn the key to the on position for one min; the turn off rehook the sensor then see if it idles correctly.
06-02-2010, 05:37 PM #3
I had this problem about a month ago, all I did is just adjust it move it around and hope you dont break it. I broke mine they cost 45 buck at autozone but it worked. Did you just install the tps sensor of did you also get a throttle body?
06-02-2010, 06:09 PM #4
06-02-2010, 11:43 PM #5
I just had to replace the Mass air flow sensor & the MAP sensor because it wouldn't
idle & kept dieing sputtering/coughing etc... & after i replaced them, the car idled perfectly, but when i would get in it, or simply try to get on the high way it would be hesitant in a way, kind of a sputter too, so that's why i replaced it.
Oh & thanks for the help!
Turns out i had the right idea, but there was a hose with a clamp right under the sensor & it would not let me rotate it as far as i needed too. So i got that out of the way & it is now idling perfectly!!
Question: Need to change Throttle Position Sensor
By LS1BL in forum General HelpReplies: 13Last Post: 02-20-2013, 12:02 PM -
Question: Bad throttle position sensor?
By clg82 in forum Firebird / WS6Replies: 7Last Post: 07-29-2010, 12:10 PM -
Throttle Position Sensor Voltage
By SilverFish in forum General HelpReplies: 1Last Post: 08-30-2008, 12:33 PM -
Fuel Problem and Throttle Position Sensor??
By GottaHaveLS1 in forum General HelpReplies: 1Last Post: 07-23-2008, 02:42 PM -
By dpinson in forum NitrousReplies: 6Last Post: 09-24-2007, 01:22 AM
