Results 1 to 3 of 3
Thread: Crankshaft position sensor help
02-13-2006, 07:37 PM #1landon00Guest
I am looking for some help on crankshaft position sensors. I am getting some really wierd behavior out of my ignition system on a 2002 5.3L conversion into a 1986 chevy pickup. I hooked a timing light up to cylinder 1, and noticed that it was not firing every cycle consistently during starting. The truck doesn't run at the moment, so I was wondering if on the 4th cycle I don't get a spark, would it be due to a weak battery. The battery is still cranking the motor over a constant speed, so I would think it wouldn't be the battery. It is consistenly every 4th revolution of the motor. My next step is to check the square wave of the Crankshaft position sensor. And also the camshaft position sensor. The truck ran two weeks ago in open loop beautifully, and now I can't get it to start. If anyone has any suggestions please let me know.
Thank you,
Landon00
02-19-2006, 03:54 PM #2Junior Member
- Nov 2005
- coral springs,florida
blue- 2000 firehawk
the first thing to check is plugs; they always tell a story. you said its been running fine in open loop; do you mean when the vehicle was cold or all the time you were running in open loop? if you are staying in open loop youre plugs will be black or fouled.you must pull at least 4 plugs on 1 bank if they are fouled,and clean or replace them if you want it to run. as far as the can and crank sensors if you are seeing a pattern youre ecu is seeing rpms they are doing their job. one sensor failure is possible but both failing at the same time is very unlikely.
02-20-2006, 07:10 PM #3landon00Guest
Open Loop
When I say open loop, I mean the engine is waiting for the O2 sensors to heat up, and then when the ECT sensor is to the right value it will try to go to closed loop. And with my engine right now it doesn't have pre-cat O2 sensors, so it can't run in closed loop yet.
Thanks for the plug input. I am going to try replacing all the plugs. I replaced all 4 of the left bank, but still haven't replaced the right bank. It still will not start with the left bank all new.
I was monitoring the crankshaft position sensor tonight with a scope and I was getting square waves out 9 V out of the sensor. That to me means the crankshaft position sensor is working. I also got a square wave out of the camshaft position sensor.
I will try the plugs tomorrow. If that doesn't work, do you have any other input as to why it will not start? I will let you know.
Thanks a ton,
Landon00
Question: 03 durango crankshaft sensor and camshaft
By JayTA98 in forum General HelpReplies: 4Last Post: 05-16-2011, 08:41 AM -
97 LT1 crankshaft position sensor and wheel?
By JaycenK in forum LT1Replies: 6Last Post: 02-16-2010, 12:56 PM -
cam position sensor
By general23cmp in forum General HelpReplies: 3Last Post: 02-20-2008, 05:47 PM -
scanned car ecu and got DTC P1336 Crankshaft Position
By voodoochi1d in forum Computer & TuningReplies: 2Last Post: 08-19-2007, 10:41 AM -
Just replaced my crankshaft sensor..still having issues
By MYSCZ06 in forum External EngineReplies: 6Last Post: 03-28-2006, 04:57 PM
