Results 1 to 20 of 21
01-12-2008, 11:05 AM #1Member
- Apr 2006
- Chowchilla CA
White- 2001 Z28
Does a high volume oil pump cause leaks?
In my recent engine upgrade a Ligenfelter high volume oil pump was installed. The oil pressure is up about 20 pounds. My pan gasket now has a slight leak. I have switched to conventional oil for the next 3000 miles (Auto RX cleaning phase). I am told that conventional oil swells the oil seals, I don't know if this is true.
01-12-2008, 03:30 PM #2Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
I believe it will as I installed a similar High Volume/High Pressure Pump and got the same results. My gauge was nearly buried untill the engine was hot and even then I was getting 60 PSI of pressure and it would jump to near 80 at any throttle. I checked it in my garage and found that it would actually steady stream oil while idleing and actually squirt it out under throttle. I changed my pressure spring to the lower one and that brought my pressure back to near 40-45 PSI at idle and the oil leak is gone. I would suggest doing the same as you will still have a High Volume unit even though you are lowering the pressure.
01-12-2008, 03:44 PM #3Member
- Apr 2006
- Chowchilla CA
White- 2001 Z28
I think you are right. I am going to go ahead and do that. The only problem is how much of a pain it is to remove a fbody oil pan.
01-12-2008, 03:47 PM #4Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
Oh I know all to well!!! I now have a BMR tubular K member which makes life a bit easier, but yeah.... I hope it all goes well. Just remember... It has to be done!
01-13-2008, 07:24 AM #5
01-13-2008, 07:27 AM #6Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Be careful about that statement Rbob! Seal conditioners are in the add packs and have absolutely nothing to do with the molecular structure of the host. Many of todays SM rated conventionals rival and add pack found in any of the synthetic oils.
01-13-2008, 07:45 AM #7
01-13-2008, 08:12 AM #8Grand Imperial Wizard
Add packs contain seal conditioners in both synthetics and conventionals.
Yes to your 2nd question. And clean by the way. And yes going back and forth from conventionals to synthetics is perfectly fine. What happens is folks go from a oil that has a poor add pack (cleaning) and the seals get crud all around them and that is what is preventing leaks....then they switch to a higher quality brand with a good add pack and it cleans the shit out of the seals and they start to leak. Same thing happens when somebody AutoRX;s a engine and blames the cleaning process for "causing" a leak...when in relaity it did its job and cleaned the crap out.....and exposed a crack or a poor fitting gasket and it started leaking.....Castrol GTX has a outstanding add pack with cleaners/seal conditioners.....good as most synthetics off the shelf....
01-13-2008, 07:34 PM #9Member
- Apr 2006
- Chowchilla CA
White- 2001 Z28
Are there any additives that are good seal conditioners? I have a couple of bottles of Valvoline Max Life additive. I am afraid to put it in my motor as it seems to be a viscosity enhancer. I have been down that road before.
I also see products that claim to stop engine leaks, something tells me they are a bad idea.
My gasket is replaced and I have backed off the oil pressure. I just want to be sure the engine stays oil-tight as the oil pressure is still higher than stock.
01-14-2008, 12:38 AM #10
01-14-2008, 12:41 AM #11Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
It was from the front seal
01-14-2008, 12:48 AM #12
around the crank pulley?
01-14-2008, 01:05 AM #13Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
Sure was! I thought at first that I might have installed the seal wron so I bought a new set of seals and still had the same problem. After changing the pressure spring though the problem was gone.
01-14-2008, 01:22 AM #14
TY good to know
01-14-2008, 03:43 AM #15Grand Imperial Wizard
I dont recommend additives...as you already know most of them just thicken the oil.....if you have a leaky gasket..... replace it....I run a Lingenfelter pump....60-70lbs of pressure....we used almost all FelPro gaskets for a reason.....not s drop after over a year has leaked anywhere.....many folks over tighten pans/valve covers etc. This causes leaks....tighten only to the recommended torque settings....
01-14-2008, 11:08 AM #16
01-14-2008, 07:54 PM #17Member
- Apr 2006
- Chowchilla CA
White- 2001 Z28
I should have asked about gaskets before I had them replaced. I am now running about 60 lbs pressure during 70MPH commuting. The gaskets are holding, for now. Would Felpro gaskets give me an edge, especially the pan gasket?
01-14-2008, 11:19 PM #18
01-15-2008, 08:44 PM #19Member
- Apr 2006
- Chowchilla CA
White- 2001 Z28
Which Gaskets should I keep an eye on?
01-15-2008, 09:07 PM #20
I've only used factory and fel-pro... Both seem like good quality. I say either-or...maybe someone else has a preference?
High HP fuel pump.
By SUP3R5T0CK in forum Firebird / WS6Replies: 12Last Post: 05-14-2012, 02:57 AM -
high volume / high pressure pump ?
By seweber in forum General HelpReplies: 4Last Post: 11-11-2011, 04:09 PM -
C6 Corvette Exhaust Install - Pump Up the Volume
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 09-04-2009, 01:20 AM -
2009 camaro price ? high volume low price OR a low volume and high price
By greatwhiteZ28 in forum Camaro / SSReplies: 10Last Post: 01-27-2007, 11:59 AM -
slp double roller timing chain & high flow oil pump how har to install?
By Irman393 in forum Internal EngineReplies: 2Last Post: 09-11-2005, 10:07 AM
I learned real quick this is an important area to use a torque wrench
