Results 1 to 13 of 13
    Jul 2011
    Utah, USA
    Red :(
    1998 Formula
    High HP fuel pump.
    I am starting a remote twin turbo setup. I know the stock pump will not handle my eventual HP goal do I'll be doing a high pressure, high gph external pump. My question is shop I keep the stock pump to feed the larger pump or remove it completely and where can I find info on doing so. Thanks
    Sent from my Galaxy S2 (E4GT) using Tapatalk 2.
    Jul 2011
    Utah, USA
    Red :(
    1998 Formula
    Sorry I guess I should say I have a 98 Formula with an in tank pump.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I have the Racetronix pump with the hot wire kit. I'm running 540rwhp on 8 psi. I'd suggest probably dual in-tank pumps. Guess it depends on what your final goal will be.
    Best bet would be to go straight to Aeromotive, Racetronix, or other reputable company and get a recommendation on a pump setup to meet your fueling needs. Last thing you want is to run that sucker out of fuel under load.
    Jul 2011
    Utah, USA
    Red :(
    1998 Formula
    I want to an external, I'm looking at a Weldon. I just not sure if should remove the in tank pump or not and if so what the process is. My stock pump went out and replaced it a few years back and did the trap door mod so I have easy access.
    Is it '98 that has the steel fuel tank?
    Jul 2011
    Utah, USA
    Red :(
    1998 Formula
    From what I remember when I dropped it, yes it is a steel tank. Maybe a replacement task should be on my list as well...
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Fuel Cell or sump the metal tank and run an external pump.
    Laurel, Maryland
    2000 Grand Prix GTP
    My setup:
    Generic installed picture:
    J -- in the generic pic, why would they loop the blue hose around the fill hose?
    Jul 2011
    Utah, USA
    Red :(
    1998 Formula
    I like that setup, what about fuel level? I want to keep mine streetable, so maybe putting a sump on the stock may be a better option. Now that I see this it makes sense on how to do it, I was focused on using the stock lines to pull from the tank. Thanks for the input.
    Super
    Laurel, Maryland
    2000 Grand Prix GTP
    The return line is the braided one next to it. I don't have that on mine, so I really don't know.
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by SUP3R5T0CK View Post
    Super
    It comes with a level sensor that goes in the top of the fuel cell.
  1. Fuel pump fuel guage issues on my '02 B4C
    By ANDYZ28 in forum Camaro / SS
    Last Post: 12-29-2014, 10:30 AM
  2. high volume / high pressure pump ?
    By seweber in forum General Help
    Last Post: 11-11-2011, 04:09 PM
  3. Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
    Last Post: 03-15-2011, 09:20 PM
  4. LS1 all yr fuel injectors, oe fuel rail, pump,more
    By Frost in forum Parts For Sale / Trade
    Last Post: 04-27-2009, 02:26 PM
  5. Replies: 3
    Last Post: 10-02-2006, 06:23 PM
