11-08-2011, 07:09 AM #1Member
- Jun 2008
- michigan
black- 1998 trans am
high volume / high pressure pump ?
Would like an opinion on oil pumps… high volume / high pressure… high pressure / standard volume …or high volume / standard pressure???
I just bought a high volume / high pressure pump for my cam bolt-on car, the car is a DD full bolt-on, 3600 stall, 9” with 3.73 it is getting a 228r cam this winter. What pump should I run?
11-09-2011, 12:06 PM #2Member
- Jun 2008
- michigan
anyone have an opinion
11-09-2011, 03:26 PM #3
I like the ported ls6 pump from texas speed
"The Camaro SS looks like it could kick your ass. The Trans Am WS6 looks like its on its way over to do it."
treat stressful situation like a dog. if you can't eat or hump it, then piss on it and walk away.
keep your foot in it,till you see god
11-09-2011, 04:02 PM #4Senior Member
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq [email protected].
11-11-2011, 04:09 PM #5Senior Member
- Apr 2008
- Madison, WI
A high volume/high pressure pump just takes more horsepower to operate...and your engine probably doesn't even need the extra volume or pressure. So you might be better off with the popular LS6 pump upgrade.
High Oil Pressure
By KnightRiderWS6 in forum General HelpReplies: 4Last Post: 12-29-2011, 07:24 AM -
Does a high volume oil pump cause leaks?
By lonewolf37 in forum General HelpReplies: 20Last Post: 01-16-2008, 04:17 AM -
high oil pressure c5?
By NIKDSC5 in forum CorvetteReplies: 5Last Post: 06-12-2007, 02:07 PM -
LS1 Oil Pressure? Too high or just right?
By Midnight02 in forum General HelpReplies: 10Last Post: 04-09-2007, 08:35 PM -
2009 camaro price ? high volume low price OR a low volume and high price
By greatwhiteZ28 in forum Camaro / SSReplies: 10Last Post: 01-27-2007, 11:59 AM
