Results 1 to 11 of 11
    JUISSED Midnight02's Avatar
    Feb 2007
    Atlanta
    2002 Camaro SS
    LS1 Oil Pressure? Too high or just right?
    I have a 2002 SS....see the list of mods below.
    I'm not sure if maybe I'm just being paranoid or not, but it seems like my oil pressure is running a bit high.
    At idle (once the car is warm), the gauge reads roughly 40 - 42 psi. At cruising speeds (roughly 2,000 rpm at 70 mph in 6th gear), the gauge reads around 60 psi and under moderate to heavy acceleration, it reads as high as 65 - 67 psi.
    Does this seem a bit on the high side. If so, anyone have an idea what could cause this and how to remedy the problem. I recently swapped the rear gear for a 3.90 and ported the throttle body (along with the bump stop mod). I've checked the oil and it reads as in the operating range....so it isn't short on oil and hasn't been overfilled.
    2002 Camaro SS M6, 2.5 PRC 5.3L heads, TFS 228/230 cam, FAST 92, bolt ons + a 10 lb bottle in the back.
    1989 Corvette L98, A4, Full bolt ons, etc.
    That is where mine is.
    I am very happy with it.
    Arkansas
    99 Trans Am
    thats about the same with mine. it will also depend on what kind of oil and filter you run too. The higher end filters will yield you less oil pressure due to more filtering/restriction.
    Feb 2007
    Atlanta
    2002 Camaro SS
    thanks guys! That sounds good to me!
    Aug 2000
    Indy
    normal to me
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    ORNGP33L 1BADDLS1's Avatar
    Long Island, NY
    Hugger Orange
    1999 Camaro Z-28
    better then normal for orignal LS1 pump.... be very happy
    J/W what oil do you run?
    St Louis, MO
    99 Firehawk convertable
    OIl pressure
    Mine runs cold at 80 warm at 65 it has 62,000 miles.
    Aug 2000
    Indy
    High rpm's I'm about 70 psi when warm , 42 when in 6th gear
    Alabama
    Mine runs 80 at idle and well hits the stop peg when im at wot. Everything is right with the guage, just some good oil pressure..haha
    98 Trans Am
    383 Stroker
    Eagle Crank, Rods
    Mahle Pistons
    Ls7 High Flow,High Volume Oil Pump- Reason for that good oil pressure
    Ls7 High Rev Lifters
    Lid,Weind Ls6 Intake
    Pacesetter LT, ORY through LMI
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Quote Originally Posted by Midnight02 View Post
    Put some extra oil in if you like to rev high often or drive hard at all. the normal range on the dip sticks means your to low.
    Feb 2007
    Atlanta
    2002 Camaro SS
    Quote Originally Posted by Hot Black Trans-Am View Post
    Will do. Thanks!
  1. high volume / high pressure pump ?
    By seweber in forum General Help
    Last Post: 11-11-2011, 04:09 PM
  2. Very high oil pressure
    By 00z28bubba in forum General Help
    Last Post: 05-25-2009, 09:02 PM
  3. High oil pressure.....
    By ggino85 in forum General Help
    Last Post: 09-22-2008, 01:34 PM
  4. Question: Can Oil Pressure be too high?
    By jrc1122 in forum General Help
    Last Post: 03-13-2008, 07:36 PM
  5. high oil pressure c5?
    By NIKDSC5 in forum Corvette
    Last Post: 06-12-2007, 02:07 PM
