    Senior Member jrc1122's Avatar
    Abilene, TX
    Liquid Red
    2009 Pontiac G8 GT
    Question Can Oil Pressure be too high?
    My Oil Pressure gauge always shows at least 60 psi (idle)-- and as soon as I give it gas it jumps all the way up. I don't even have to floor it, just accelerate normal, and it stays very high 70+ PSI.
    I think the lowest I have ever seen it, was about 40 PSI (that is after I have been driving for a while, and I am stopped with the clutch in.
    My question-- Is this, or could this lead to, a problem??
    If this is a potential problem, what can I do to fix it. (before it becomes an issue)
    Car seems to drive completely normal by the way.
    2009 Pontiac G8 GT
    Liquid Red
    Real cars are RWD. PushroD's Avatar
    Feb 2006
    Chicago 'burbs
    Midnight blue metallic
    1999 Trans Am
    Thumbs up
    I wouldn't worry about it. Mine also reads rather high. (40psi at idle minimum) it won't hurt it. I do have an ls6 oil pump installed though. There is always the possibility the oil pressure sender is going bad, which in itself isn't terrible, just replace it. It's cheap, and a quick fix, just remove the intake manifold to access it.
    Abilene, TX
    Liquid Red
    2009 Pontiac G8 GT
    Thanks, anyone else have an opinion or facts?
    Senior Member OnEbAdReDSS's Avatar
    Puyallup
    2000 Camaro SS # 5,876
    ummm i just replaced the oil sender unit and it reads a little higher than normal... oh well... i just did the LS6 Manifold Swap...
    NC
    1998Z28
    Consider yourself blessed by the Bearing Gods!!
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    Quote Originally Posted by PFM View Post
    Parma Heights, Ohio
    SOM
    99 Trans Am
    Mine is the same way. I look at it as a good thing. Id rather have somewhat high oil pressure than none at all!
    Cedars, Pa
    '02 Camaro SS
    My pressure runs about the same in my '02 SS. I have found that these oil pressure gages aren't very accurate however. I've had three gage pods put in my '03 Silverado. The last one, the pressure dropped 10 psi across the board just from a gage change.
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    I would only worry about high oil pressure if it was insanely high and you did not have a good reason for it. The stock pump should not max out your gauge all the time. The only reason I would worry is because something could be causing a blockage, but it is still in the gauge consider it a good thing.
  1. high volume / high pressure pump ?
    By seweber in forum General Help
    Last Post: 11-11-2011, 04:09 PM
  2. Very high oil pressure
    By 00z28bubba in forum General Help
    Last Post: 05-25-2009, 09:02 PM
  3. High oil pressure.....
    By ggino85 in forum General Help
    Last Post: 09-22-2008, 01:34 PM
  4. high oil pressure c5?
    By NIKDSC5 in forum Corvette
    Last Post: 06-12-2007, 02:07 PM
  5. LS1 Oil Pressure? Too high or just right?
    By Midnight02 in forum General Help
    Last Post: 04-09-2007, 08:35 PM
