    Jul 2011
    Harrison AR
    1999 Trans Am WS6
    High Oil Pressure
    The oil pressure on my 99 WS6 has been pegging out around 80. It usually ran around 40 to 60 but the last couple of weeks its been higher than normal. It's been kinda cool but last winter it ran high til the motor warmed up then it would fall back to normal. The motor is not making any noises but it seems like its been on the sluggish side. Any ideas?
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Are you using the stock guage, or an aftermarket one? The stock guages are notorious for not being very accurate.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Try a mechanical gauge to test with or if you have a good scanner you can pull info from the computer but that is coming from the OPSU and if that is bad then the scan info will ne bad so try the old school gauge to see what is really going on.
    Jul 2011
    Harrison AR
    1999 Trans Am WS6
    I've been using the stock gauge.
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by 2002ssslp View Post
    Agreed, a remote guage will be far more accurate than the factory guage.
    The factory oil pressure guage on these cars is basicly there only to let you know the engine has oil pressure.
    Beyond that it's not the sightest bit accurate...
    A true quality guage will show even the slightest fluctuations in oil pressure..
  1. high volume / high pressure pump ?
    By seweber in forum General Help
    Last Post: 11-11-2011, 04:09 PM
  2. Very high oil pressure
    By 00z28bubba in forum General Help
    Last Post: 05-25-2009, 09:02 PM
  3. Question: Can Oil Pressure be too high?
    By jrc1122 in forum General Help
    Last Post: 03-13-2008, 07:36 PM
  4. high oil pressure c5?
    By NIKDSC5 in forum Corvette
    Last Post: 06-12-2007, 02:07 PM
  5. LS1 Oil Pressure? Too high or just right?
    By Midnight02 in forum General Help
    Last Post: 04-09-2007, 08:35 PM
