Results 1 to 3 of 3
09-09-2005, 01:12 PM #1
slp double roller timing chain & high flow oil pump how hard to install?
just what the title said..how hard would it be to put a new double roller timing chain and new oil pump?? is it possible to be done at home or do i need to take it to a shop??? nebody please let me know..or any websites that can walk me thru it would be very appriciated
09-11-2005, 02:48 AM #2
It can be done. Just replace the front main seal and I inspect the timing cover gasket. If it still looks good I just put some RTV (Permatex) in the corners. You will also need the new O ring for the oil pump. And as for the rest. WWW.LS1HOWTO.COM.
09-11-2005, 10:07 AM #3Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
pretty easy..not too hard. your more than likely gonna have to drop the oil pan and remove the bottom 2 bellhousing bolts. slip a rag under the oil pump to catch the screw in case it falls.
Question: double roller timing chain
By 20ws6speed01 in forum Internal EngineReplies: 4Last Post: 01-12-2011, 12:35 PM -
Cam/Oilpump/Double Roller Timing Chain
By Whiteboycntdnce in forum Internal EngineReplies: 5Last Post: 01-26-2008, 11:15 PM -
FS: New Never Used Rollmaster Double roller timing chain
By jimmypop13 in forum Parts For Sale / TradeReplies: 0Last Post: 05-21-2007, 07:08 PM -
SLP Timing Chain, 1997-03 LS1/LS6 Double-Roller
By Stealthperf.com in forum Parts For Sale / TradeReplies: 0Last Post: 01-07-2007, 03:33 PM -
By Stealthperf.com in forum Parts For Sale / TradeReplies: 2Last Post: 10-15-2006, 04:35 PM
