Results 1 to 20 of 20
Thread: Wont start
12-02-2007, 03:19 PM #1
Wont start
I have a 1998 TA I just completed a 6.0 swap. It will turn over and will fire if you give it a sniff of starting fluid. The fuel pump is running I checked the fuse's and the ENG SEN fuse under the hood was blown and keeps blowing. But with it blown the starting fluid will help it fire just for a cupple seconds. Can the ENG SEN have anything to do with it ? Any help would be great.
12-02-2007, 04:28 PM #2
it sounds like its not getting fuel what its running on is just the starter fluid , then once it is all burned it obviously stalls out
12-02-2007, 04:40 PM #3
have u cked the fuel lines going to the right place
12-02-2007, 09:13 PM #4
I never disconeted the fuel lined I just unbolted the fuel rails and layed them to the side with the lines still hooked up.
12-03-2007, 04:56 AM #5
ok them have u cked al ur grounds, r they hooked to wear they need to be.try to put a biger fuse by # i mean,and make sure ur fuel is comeing up if it is it might be that fuse.
12-03-2007, 05:59 AM #6
check the fuel rail pressure to make sure you are getting fuel up there
12-03-2007, 09:46 AM #7
I pushed the valve and gas is coming out and seams to have presser. Im pritty shure I have all the grounds hooked up.
12-03-2007, 11:08 AM #8
are your fuel injectors hooked up correctly? all the wires and grounds to them
12-03-2007, 01:21 PM #9
I have the injectors pluged in. The ground ? If it is one of the 3 grounds that bolt on to the back of the heads then yes it is grounded. How can i check to see if the injector are working is there a test I can run? Thanks so much Chad
12-03-2007, 01:50 PM #10
Are the fuel injectors flowing?
I had this exact issue when I swapped an engine into my Ranger pickup.
Turned out the fuel in the injectors had turned to varnish.
Replaced the injectors and all is ducky.
As far as checking if the injectors are firing, there is a test light that plugs in in place of the injector. It blinks when the computer is trying to fire the injector. That's how I found my problem. A friend used to be a mechanic at a dealer and he loaned me his test light.
Good Luck!
12-03-2007, 04:05 PM #11
yes this tester are sold at ur local auto parts.good luck
12-03-2007, 05:50 PM #12
we mite of narrowed it down
12-05-2007, 02:03 AM #13
Thanks so much I will try running the test. The car has'nt set that long I dout it is varnish but you never know at least i wil know that there firing. I will keep you updated.
12-07-2007, 10:16 PM #14
OK I forgot to ask what kind of fuel pressure do I need????? Im going to check it tomarow.
12-08-2007, 04:09 AM #15
Don't think you should ignore problem #1( ENG SEN fuse blows) and move on to #2,engine won't start until #1 is solved
Service manual says ENG SEN fuse has to do with O2s,MT6,MAF sensor!!!,and stop lamp switch
Maybe something with the way the MAF is connected? I'm thinking you need fuel AND air for ignition so maybe MAF problem?
Good Luck ,keep us posted.
12-08-2007, 01:18 PM #16
IT'S ALIVE my dumb ass forgot to plug in the crank sen. It's behind the starter. It fired right up. As far as the fuse I had pinched a o2 wire I moved it and fixed that problem .
When your doing a project like this all you have to do is take your time. And time is somthing I dont have. I got in a rush and look what happend I end up spending more time in the end. Thanks so much for the help. Chad 1998 WS6 ram air 6speed vert.
12-08-2007, 02:53 PM #17
Good news! Let us know how fast it turns out!
12-08-2007, 03:03 PM #18
i have a question. dont kill me because i know this is a simple one but if the O2 sensor can make the car run bad and use more fuel, then what actually happens when you eliminate them when running an ORY.
12-08-2007, 06:55 PM #19
I know before when I had them unhooked it run like shit. That all I know sorry.
12-08-2007, 08:23 PM #20
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Z71 wont start
By duranws6 in forum General HelpReplies: 4Last Post: 01-09-2013, 07:49 PM -
LT1 wont start
By Bad Co. in forum General HelpReplies: 8Last Post: 11-18-2010, 07:23 AM -
LT1 wont start
By Bad Co. in forum LT1Replies: 0Last Post: 11-16-2010, 05:32 PM -
car wont start
By redss2000 in forum General HelpReplies: 12Last Post: 06-20-2008, 01:06 PM
