Results 1 to 15 of 15
    nc
    1998 TRANS AM
    lt1 wont start need help fast
    ok so i riped out my engine and change the cam and heads and a bunch of other stuff. but its all back togather. my other threads are about opti's but i put a new one in and now i get spark and it pops every onces in awhile when i am cranking i checked the fuel pres, all new plugs and wires. could i have done something wrong
    i was woundering if my rockers are to tight and all the valves are open could cause this. im going to do a compression test but wanted to now more possibleties
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Like you said, get the compression test and see what it is. Its kind of hard to tell you whats wrong.
    nc
    1998 TRANS AM
    when it pops flames come out of my headers. just an update
    Aug 2006
    Missouri
    94 Camaro Z28
    Timing might be off?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    check the firing order.
    nc
    1998 TRANS AM
    ok so i check the compression and i didnt reallly get any where because it says it has no compression in cylinder 1 havent checked the otheres yet toke the valve cover off to see the rockers and they are to tight but it still doesnt expline the no compression in number 1 after i loosen it . could i have got bad head gasket or something
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Well if you had a bad head gasket I think you would of had warnings like leaking green fluid from the exhuast or white smoke coming out of the exhaust as well, the car will still be able to crank and the motor would would be shaking.
    nc
    1998 TRANS AM
    ok here is the update car started rockers to tight cant keep an idle but i checked the fuel and it say it has 10-15 psi at the shrader with just the ing on. i put on a new areomotive fuel pres. reg. on so i think i have to adjust it and it should stay running i hope if you guys have and suggestion please give me some imput.
    Feb 2006
    Orange County, NY
    always dirty
    10-15 is way too low. it should be somewhere near 45 psi I think.
    nc
    1998 TRANS AM
    yeah i know im just happy it started, im done for tonight its giving me a head ache.
    where you from in NY bigrondownhiller
    Feb 2006
    Orange County, NY
    always dirty
    suffolk cty long island
    nc
    1998 TRANS AM
    i used to live in albany until i went in the marines. im going up long island in a couple of weeks
    Feb 2006
    Orange County, NY
    always dirty
    do you have friends or family here?
    nc
    1998 TRANS AM
    no my wife has a interview down in stoney brook to go to school. i have family in albany.
    Feb 2006
    Orange County, NY
    always dirty
    that is about 10 minutes from me.
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 08:54 PM
  2. Help: wont start!!!!!!!!!!!!!!!!!!!!!!
    By victor111262 in forum General Help
    Last Post: 09-30-2010, 10:18 PM
  3. Car wont start PLEASE HELP!!!
    By RS_SS69 in forum General Help
    Last Post: 06-07-2007, 10:39 AM
  4. car wont start
    By bdavies11 in forum General Help
    Last Post: 08-16-2006, 04:18 AM
  5. Car wont start! pls help
    By jinxeng in forum General Help
    Last Post: 07-24-2006, 06:46 AM
