Results 1 to 2 of 2
Thread: Car wont start PLEASE HELP!!!
06-07-2007, 09:47 AM #1
Ok a buddy and I were installing my nitrous and we were drilling the plastic shroud below the wipers to run the purge and drilled to deep and hit the main harness and broke a few wires so the car wouldnt idle below 2500rpm! We then pulled the harness out a bit to repair the wires, checked all the fuses and relays and now the car cranks and will not start, it seems like I have no spark, (will confirm that later today), I also have a SES light on but no scanner, is it possible that I pulled a wire out of the crank sensor when I pulled the wiring harness a bit or what else could be the problem? The car ran before we pulled the harness a bit to fix the wires.
06-07-2007, 10:39 AM #2
Never drink beer when messing with a drill, while working on your ride.
Try resetting the pcm. check all connections.
Hope all works out.
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Z71 wont start
By duranws6 in forum General HelpReplies: 4Last Post: 01-09-2013, 07:49 PM -
LT1 wont start
By Bad Co. in forum General HelpReplies: 8Last Post: 11-18-2010, 07:23 AM -
LT1 wont start
By Bad Co. in forum LT1Replies: 0Last Post: 11-16-2010, 05:32 PM -
car wont start
By redss2000 in forum General HelpReplies: 12Last Post: 06-20-2008, 01:06 PM
