Thread: car wont start
08-15-2006, 03:08 PM #1Junior Member
- May 2006
- Florida
tan- 2000 Camaro
car wont start
Hey guys, ive got a 2000 v6 coupe and for the past few weeks ive had all kinds of trouble getting it started. Of course the first thing i did was replace the battery since i hadent replaced it in about 2 years. That didnt help. So then i had my step dad look at it ( he works for chevy ) and he said the starter motor (he had some funny name for it) needed to be replaced. He replaced it for me and it was fine for about 2 days and now its having troubles starting again. In fact it wouldnt start at all today. :-( I do have a 900rms amp hooked up to 2 12" subs but have never had any problems with voltage drop or electrical issues even with them slammin. If anyone has any ideas of what the problem could be, please, help me. Thanks.
08-15-2006, 04:01 PM #2
I would find out what he replaced and post..
08-15-2006, 05:31 PM #3Junior Member
- May 2006
- Florida
tan- 2000 Camaro
Ok i found out that he replaced the crank sensor. So i have a new battery and new crank sensor and im still having problems starting it. It will start sometimes and sometimes it wont.
08-15-2006, 09:07 PM #4
Does it crank but not start or does it just act like the battery is dead? What does it do when you try to start it?
08-15-2006, 10:32 PM #5Junior Member
- May 2006
- Florida
tan- 2000 Camaro
No, it does not act like the battery is dead. It does crank, it just wont start.
08-15-2006, 10:49 PM #6
When you turn the key on do you hear the fuel pump prime and have you checked the fuel pressure? I don't want to send you on a wild goose chase but I would check to see if you're getting spark and then check to see if you're getting fuel. That would be the first things I would check.
08-15-2006, 10:53 PM #7
your fuel pump might be dead. if you repalaced the battey and your starter is working you could have a bad fuel pump.
08-15-2006, 10:54 PM #8Junior Member
- May 2006
- Florida
tan- 2000 Camaro
I dont know if i could tell if i could hear the fuel pump prime. Not sure what it would sound like. Im not the best with mechanics. :-(
08-15-2006, 10:55 PM #9
When you turn the key to run but don't start the car you should hear a little buzzing type sound that lasts about 2 seconds coming from the rear of the car. That's your pump priming.
08-15-2006, 11:05 PM #10Junior Member
- May 2006
- Florida
tan- 2000 Camaro
08-15-2006, 11:14 PM #11Junior Member
- May 2006
- Florida
tan- 2000 Camaro
Also, before he replaced the crank sensor the other day he had me try to start it to see if it was getting a spark and he told me it wasnt. After he replaced it, it fired right up and i drove it home and when i got home , fired it up a few more times just to test it and it was fine. So we thought it was fixed. But now since its still having problems i would have to say no, its probably still not getting a spark. So i guess the next step is to check the fuel pressure.
08-16-2006, 04:18 AM #12
when you turn your key too the run position, stick your head out the door and listen, Its kinda like a high pitch whineing, You will know if you hear it or not.
Hook up a fuel pressue guage and see if your gettin fuel, If you are then check for spark like said above, You can either get a nifty "in line" tester. You hook on end too plug and one end into wire and crank too see if the lil light inside lights up or just pull a plug and try and arc it off of something metallic.
J
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Z71 wont start
By duranws6 in forum General HelpReplies: 4Last Post: 01-09-2013, 07:49 PM -
LT1 wont start
By Bad Co. in forum General HelpReplies: 8Last Post: 11-18-2010, 07:23 AM -
LT1 wont start
By Bad Co. in forum LT1Replies: 0Last Post: 11-16-2010, 05:32 PM -
car wont start
By redss2000 in forum General HelpReplies: 12Last Post: 06-20-2008, 01:06 PM
