    Jun 2006
    san francisco, ca
    blue
    2000 camaro z28
    Car wont start! pls help
    i have a 2k z28. it was driving all fine and dandy until i parked it. when i returned, i put the key into the ignition, all electrical started working. once i tried to start the engine, i heard a click and everything in the car died including the power. pull the key out and re-inserted into the ignition. no power, nada. opened my hood, moved the battery, tried pushing in the electrical wirings and made sure it was all snugged and stuff. went back to the car, reinserted the key into the ignition and the power worked. cranked it, heard the same click and everything died.
    repeated the entire process twice, then somehow got the engine started. anyone knows what the problem maybe ? i havent driven the z28 in so long, about 2 years. battery was dead for a while until i jumpstarted and recharged it again. could it be the battery ? not sure cause the power worked just until i started to crank the engine. thanks for your help.
    nj
    90 Mustang 5.0
    start with a new battery. then work from there
    Bragg NC
    Met. Sunset Orange
    01 SS
    I agree with above get your battery tested or test with a multi-meter. Sounds like your battery has taken a poo on you. Check your connections on ur battery and tug on the starter wires too make sure there snug and good to go.
    J
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Starter could be going. More than likely that "click" you heard was the starter "pull in" windings pulling the starter pinion . Test volatge at solenoid. The first action of the solenoid is mechanical, pulling the drive pinion into mesh with flywheel. Second job is to act as a relay switch to energize motor once the D. pinion is engaged. Once contact points are closed, full battery current flows to starter motor.There are other causes also with a starter. If the battery renewal doesnt help i will write some tests you can do to trace a starter pooin on you. lol.
    Either a loose connection or starter. There was an older couple in a Wal-Mart parking lot a couple of years ago that were having the same problem in a van. I stopped to help and when he would turn the key it would click. I took his tire iron and knocked the shit outta the starter and it fired right up. That was just a sticking solenoid I guess.
    BAD INFLUENCE mad3125's Avatar
    aston,pa 19014
    1998 pontiac trans am
    i had the same thing happen to me in my 89 turbo ta,and it turned out to be the ignition,where the chip in the key meets ,whatever it meets inside the ignition was bad,and the car to this day only has 30 k on it . not saying for sure thats what it is ,just giving you some ideas!
    maroonZ
    Guest
    check the battery terminals for corrosion. if not the battery is fried
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    same thing happened to me and it was just loose connections on the battery terminals
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    If there is corrosion, the coke trick works prettty good for the short term to get it started.
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 08:54 PM
  2. Z71 wont start
    By duranws6 in forum General Help
    Last Post: 01-09-2013, 07:49 PM
  3. LT1 wont start
    By Bad Co. in forum General Help
    Last Post: 11-18-2010, 07:23 AM
  4. LT1 wont start
    By Bad Co. in forum LT1
    Last Post: 11-16-2010, 05:32 PM
  5. car wont start
    By redss2000 in forum General Help
    Last Post: 06-20-2008, 01:06 PM
