Results 1 to 2 of 2
    Farmington Hills, MI
    1998 Camaro Z28
    Clutch Not Fully Disengaging (Spec 3+)
    2000 WS6
    Spec Stage 3+ Clutch
    Symptoms:
    -Clutch engagement is literally right off of the floor
    -Cant shift out of first or into second near redline until revs drop
    -Popping out of 3rd occasionally
    -Light Grinding into 4th & 5th
    Previous owner had "new hydrolics" installed right before i bought it.
    So what exactly did they do wrong?
    -Not leaking any fluid
    -Could it be a simple bleeding issue?
    -Slave cylinder not shimmed properly or shimmed at all?
    I need to sell the car, but want to get this issue fixed first. I am prepared to
    drop the tranny to look at the slave cylinder or clutch setup if necessary, but would rather not if its avoidable. Any help would be appreciated. Thanks guys.
    1998 Camaro Z28
    Whoops i guess this should be in the manual transmission section. Mods move please.
  1. Question: T56 Clutch not disengaging after new clutch installed
    By Brownsugar in forum Manual Transmission
    Last Post: 09-25-2014, 04:15 AM
  2. ram force 9.5 clutch not disengaging
    By spike669 in forum Drivetrain
    Last Post: 04-24-2012, 03:00 PM
  3. Clutch not disengaging
    By 1999sscamaro in forum Manual Transmission
    Last Post: 04-13-2012, 05:34 PM
  4. Clutch not disengaging 100%?
    By rossi1369 in forum Manual Transmission
    Last Post: 04-25-2011, 07:57 PM
  5. Help: New Clutch won't fully disengage
    By JaredTbo in forum Manual Transmission
    Last Post: 04-23-2009, 07:27 AM
