Thread: Clutch not disengaging 100%?
04-22-2011, 09:08 AM #1Junior Member
- Jun 2007
- NJ
Blue- 2000 Trans Am
Had the rear jacked up the other day, and with the car in gear and the clutch fully depressed, the wheels spin...Is this normal?
The wheels do not spin in neutral.
Under normal driving, the clutch does not really start to grab until letting out the pedal 1/2 way. The car drives normal, but the clutch is slipping (SPEC 3) and im going to replace this summer.
Just curious if this is normal, or if I have a slave cyl/alignment issue also...
04-22-2011, 10:25 AM #2
04-22-2011, 06:43 PM #3Senior Member
- Apr 2008
- Madison, WI
With the car in the air like that its hard to tell. could just be a little drag from the pilot bearing causing the wheels to spin.
Do the "on the ground" test like VENOMOUS said
04-25-2011, 05:52 PM #4Junior Member
- Jun 2007
- NJ
Blue- 2000 Trans Am
The car will never move forward on the ground...everything is normal. Jacked my cousin's T/A in the air and his wheels did not spin like mine...I dont think anything is really wrong, I was just curious if it was normal....
04-25-2011, 07:57 PM #5Senior Member
- Apr 2008
- Madison, WI
I'd say your clutch is releasing ok or mostly ok then. There might be a very very slight drag from the clutch when its supposed to be released. I'd probably not worry too much about it.
Question: T56 Clutch not disengaging after new clutch installed
By Brownsugar in forum Manual TransmissionReplies: 6Last Post: 09-25-2014, 04:15 AM -
ram force 9.5 clutch not disengaging
By spike669 in forum DrivetrainReplies: 0Last Post: 04-24-2012, 03:00 PM -
By 1999sscamaro in forum Manual TransmissionReplies: 3Last Post: 04-13-2012, 05:34 PM -
Clutch Not Fully Disengaging (Spec 3+)
By bg552 in forum DrivetrainReplies: 1Last Post: 10-15-2007, 06:55 PM -
Transmission disengaging
By dixonk in forum Manual TransmissionReplies: 2Last Post: 05-19-2006, 07:03 AM
