Results 1 to 3 of 3
Thread: Transmission disengaging
05-18-2006, 10:08 AM #1Junior Member
- May 2006
- Kuwait
Silver- 2002 Trans Am WS6
When normal driving, transmission is working fine, but when I am racing the car from a dead stop first gear has no problem. I push the engine to red line and then shift to 2nd. Once in second I can get to about 4000rpm and then it completely disengages. No matter what gear I go to, same problem, until I slow back down to around 1200 rpm. Today I changed my fuel filter, plugs, and plug wires. What is wrong with my tranny???
05-19-2006, 03:54 AM #2Member
- metro Detroit area
It sounds like clutch slip to me. Your trans gears are a constant-mesh design. Once engaged they cannot slip and recover. They may jump out of gear or break and produce no drive but they cannot slip.
05-19-2006, 07:03 AM #3Junior Member
- May 2006
- Kuwait
today I took it out and ran it out on the freeway I live overseas so the speed limits are much higher than the states. It disengaged after 125 mph until I brought it down to 75 again then it reengaged. This was in 6th gear by the way. After market parts are hard to get but should be able to get parts from the chevy dealer will a clutch from a Z06 work with mine???
Question: T56 Clutch not disengaging after new clutch installed
By Brownsugar in forum Manual TransmissionReplies: 6Last Post: 09-25-2014, 04:15 AM -
ram force 9.5 clutch not disengaging
By spike669 in forum DrivetrainReplies: 0Last Post: 04-24-2012, 03:00 PM -
By 1999sscamaro in forum Manual TransmissionReplies: 3Last Post: 04-13-2012, 05:34 PM -
Clutch not disengaging 100%?
By rossi1369 in forum Manual TransmissionReplies: 4Last Post: 04-25-2011, 07:57 PM -
Clutch Not Fully Disengaging (Spec 3+)
By bg552 in forum DrivetrainReplies: 1Last Post: 10-15-2007, 06:55 PM
