    May 2008
    TX
    Question New Clutch won't fully disengage
    A buddy and I just put a new Spec stage 2+ clutch/alum press plate, alum flywheel, new slave and master cyl in my 00 SS. After doing the entire project twice because we couldn't get the clutch to disengage, we put in an extra spacer behind the slave cyl in addition to the one that came from Spec. Now at least it's drivable, but it's obvious it's somewhat grabbing. Putting it in first gear at a stop is very tough, reverse is pretty much unusable. I know the standard answer is to bleed it more, but we've literally spent hours bleeding it using every technique we read here and from several mechanics. Is this normal and will go away with break-in? Should we put in extra spacers? Any other ideas?
    San Antonio
    Silver & Black
    99 Camaro SS
    I put in a Spec (al. press. plate) and al. flywheel with a new slave. Mine engaged and disengaged from the start. The engagement feel gets better with some use.
    I'd remove the shim. It is there to ensure the clutch engages fully. You have the opposite problem...so I'd remove both. So now you are thinking...then why did adding one help! I can't be sure but it might be due to a combo of how things were seated and possibly torqued...along with some break in from the previous attempts and driving.
    But you are dealing with something I wouldn't be wating on time or brake-in to alleviate!
    Member side2000's Avatar
    md
    2000 camaro ss
    does your pedal still release all the way like the stocker did? you may need to adjust your master at the pedal. only other thing i can tell you is maybe get an adjustable slave.
    the "madden answer" would be to make sure you have enough fluid.
    May 2008
    TX
    Yep, fluid level is good and pedal quickly relieves all the way. The pedal is actually much more firm through its whole travel than stock, but actuation of the clutch happens right at the floor.
    md
    2000 camaro ss
    are you using stock slave? did the shaft bend? a lotta times the shaft bends because of the added spring pressure of clutch
    May 2008
    TX
    It's a new slave, but just a standard AC Delco replacement. The shaft didn't seem bent, but we didn't inspect it super close so we'll have to take a look when we drop it again next weekend like we're planning.
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    I had the exact same problem with installing my LS7 clutch, turned out to be a bad master cylinder. Had pressure, everything seemed fine, except that the clutch would never fully disengage. Replaced the master again, and I was on the road again. Hope you find a solution soon!
    San Antonio
    Silver & Black
    99 Camaro SS
    I'd have a blown a cylinder over that!
    Compared to going back into the clutch...I might try the old master if you still have it.
    s.fla
    02 z28
    We had the exact same prob w/1st and reverse, but ours is and yours may not be our racing headers (hooker) the #7pipe was just inches away from the clutch line and cooking the fluid, therefore burning out the slave & master, we had to replace the slave and master of course but then put a heat shield inbetween the pipe and the line and also heat resistant sleeves (doubled) around the line to keep it insulated. No more problems, smoothe as silk. Also bleeding, take the line completely out of the car it has to be at an angle, won't work while in the car. hook line to something have master at the bottom of line and bleed - north to south/top to bottom never level, won't work.
    Member fast enough Z28's Avatar
    Rowlett,Tx.
    98 camaro z28 m6
    Just get an adjustable master cylinder. The one by ram worked great. I had the same problems
    Marylandistan
    2001 Trans Am (sold)
    Possible bent splines on the input shaft causing the clutch to hang up? Just throwing something else out there.
    Jan 2008
    ottawa
    1998 pontiac transam ws6
    hey i know this is kind of late but i was wondering if you have found a solution? im having this issue as we speek..
  1. Help: Clutch won't disengage - Throwout Bearing Install
    By x10-wakerider in forum Manual Transmission
    Last Post: 07-13-2009, 05:16 PM
  2. Help: A/C Compressor won't disengage in time
    By sewer rat in forum General Help
    Last Post: 07-06-2009, 08:45 AM
  3. Clutch won't disengage?
    By rchops33 in forum Manual Transmission
    Last Post: 04-08-2008, 05:34 AM
  4. Clutch Not Fully Disengaging (Spec 3+)
    By bg552 in forum Drivetrain
    Last Post: 10-15-2007, 06:55 PM
  5. Help! Clutch won't disengage!I think!
    By '99 SLP#24 in forum Manual Transmission
    Last Post: 10-18-2006, 11:14 PM
