    Go Vols! x10-wakerider's Avatar
    Memphis
    SLP Camaro SS
    Clutch won't disengage - Throwout Bearing Install
    I just replaced the throw out bearing and after vacuum bleeding it with a mighty vac the clutch still wont disengage. Could I have done something wrong during the install or do I need to keep bleeding? I did not bleed the throw our bearing because I was told it was pre-bleed. I used the link below for mighty vac bleeding instructions.
    http://www.performanceworks1.com/ls1...h_bleeding.htm
    Jun 2009
    tinley park il
    99 trans am ws6 ram air
    keep bleedin it took me 2 hours to bleed mine
    Quote Originally Posted by chuckunit69 View Post
    +1 same here, I was getting seriously pissed off, because I was thinking the master was bad and didn't want to have to pull it out to get another one...
    Memphis
    SLP Camaro SS
    I bleed it some more and that fixed it! Thanks!
    Member devildogws6's Avatar
    Monticello MN
    2000 trans am ws6
    wont disengage i had the same problem but with mine it was because two springs on my clutch broke!!!
  1. scratching noise---throwout bearing?
    By jmatt07 in forum Manual Transmission
    Last Post: 01-30-2009, 06:27 AM
  2. throwout bearing size?
    By ldanny in forum Manual Transmission
    Last Post: 06-17-2008, 02:00 PM
  3. fork and throwout bearing
    By pelniz in forum Drivetrain
    Last Post: 07-08-2007, 01:36 PM
  4. Throwout Bearing
    By Dancswbirds in forum Firebird / WS6
    Last Post: 07-27-2006, 11:35 AM
