    Buffalo
    Orange
    1999 Camaro
    Clutch won't disengage?
    Guys,
    Here's the scenario:
    If I have the engine turned of, I can shift into a gear, start the engine and the car will move. If I pull it out of that gear and try putting it into any other gear (including the one it was just in), I can get it into gear. The only time I can get it into gear is if I shut the engine off. What could be my problem here?
    Thanks.
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    You said it will go into gear with engine shutoff and then when you crank it, the car will start moving. Is that with your clutch pedal to the floor???
    Could be several things, Master Cylinder, Slave Cylinder, Clutch, or throwout bearing. Or maybe something really simple, air in the lines or empty no fluid. Have you checked the reservoir?
    Buffalo
    Orange
    1999 Camaro
    Yes...the resrevoir is full. The line isn't leaking. The clutch pedal still has pressure on it when I push it to the floor.
    ASC #753
    hmmm, sounds like you may need to drop the tranny and see if it tells the story.
    metro Detroit area
    This sounds like a clutch release issue. I would exhaust the clutch investigation before I tear into the trans.
  1. Help: Why do my headlights pop up when i disengage parking brake??
    By GianoRanger2000 in forum Firebird / WS6
    Last Post: 10-12-2012, 01:42 PM
  2. Help: Clutch won't disengage - Throwout Bearing Install
    By x10-wakerider in forum Manual Transmission
    Last Post: 07-13-2009, 05:16 PM
  3. Help: A/C Compressor won't disengage in time
    By sewer rat in forum General Help
    Last Post: 07-06-2009, 08:45 AM
  4. Help: New Clutch won't fully disengage
    By JaredTbo in forum Manual Transmission
    Last Post: 04-23-2009, 07:27 AM
  5. Help! Clutch won't disengage!I think!
    By '99 SLP#24 in forum Manual Transmission
    Last Post: 10-18-2006, 11:14 PM
