    florida
    04 GTO
    starting problem
    First of all over the last 6 months I have replaced the battery, alternator & starter (in that order). Everything has been fine until this morning when I tried to leave for work it wouldn't start and I had to jump it off. I went to start it a few minutes ago and it acted as though it was going to start and then everything went dead as a hammer as soon as I turned the key. Now nothing is working. Anyone have any suggestions???
    Bragg NC
    Met. Sunset Orange
    01 SS
    Why did you replace the battery, and alt? Were you having problems?
    Sounds like just a dead battery, get it running again and have the system load tested. That will test the entire charging system. Local parts stores do it for free. Do you have a multimeter? You can also check it that way. Are your battery terminals good and tight? Clean?
    J
    florida
    04 GTO
    Yeah it was actually my alternator that was pulling the battery down but I didn't figure that out until it was too late. Then two weeks ago my starter went out and I figured no big deal it's 10 years old afterall but now I don't know what's going on.
    Bragg NC
    Met. Sunset Orange
    01 SS
    So the battery was drained by the alt previously? The battery might be done, have the system checked and see if you have a warranty on the battery.
    Which alt did you replace it with?
    J
    florida
    04 GTO
    That's what I was thinking. I replaced it with a new one from Advance (pallidium or something like that). I doubt the battery has a warranty b/c I got it from walmart b/c they were the only place open at the time and I had to get to work.
    Since you had already replaced the battery and alt I would look more at the cables first. Check your cable ends and make sure they're not corroded. Might look fine on the outside but peel back a little bit of the insulator and look at the wires just past the connectors and make sure they aren't corroded.
    florida
    04 GTO
    I know that before I replaced the alternator that it was already draining my new battery so I hope that's what it is but I do wonder if one of my wires that run right next to the aftermarket headers going to the starter haven't went bad. I'm going to check that first before I leave work today.
    florida
    04 GTO
    I'm a dumbass....I didn't tighten the positive terminal down good. Guess I over thought that one!!!!
    Cedar, KS
    Pewter Metallic
    2000 NHRA Trans Am
    Mine just did the EXACT SAME THING!!!
    I don't think it has to do with the battery. I pushed and pulled the cables and it came on. No battery problems prior. Ran fine after going through the computers relearn cycle. Shut it off, then it started normal a couple times, then it was dead.
    What happens is it gets all the lights on as you turn the key... then it just dies. Then it is all dead.
  1. Question: starting problem
    By Faught in forum General Help
    Last Post: 10-07-2010, 11:13 AM
  2. Starting problem.
    By Hawk01Eye in forum General Help
    Last Post: 04-11-2010, 07:03 PM
  3. Starting problem
    By Da Wookie in forum General Help
    Last Post: 07-17-2009, 06:50 PM
  4. Starting Problem !!!!
    By ROLLIN1200 in forum GM Trucks
    Last Post: 09-21-2007, 05:06 PM
  5. need help with starting problem
    By tds1213 in forum General Help
    Last Post: 06-20-2007, 06:46 AM
