Thread: need help with starting problem
06-18-2007, 08:29 PM #1Junior Member
- Jul 2006
- washington
white- 94 camaro
I have a wierd starting problem in my 94 z28. If you try to start the car cold it wont turn over as if the battery was dead but if you turn it on and off really fast repeatedly it will eventually start. But once it starts and warms up it will start right back up with no problems. Any ideas what could be causing this. Someone had a vague idea that it might have something to do with the ignition cylinder. Does this sound like it could be the problem and does anybody know how to test it? Thanks.
06-19-2007, 07:34 AM #2
Yep, sounds like your passkey/VATS needs help. Is your key really old? How does the resistor look? Is the cylinder heavily worn? Autozone sells cyl&key replacements for about $60...
-Eagle
06-19-2007, 08:32 PM #3
not sure on the obd1 cars but on the obd2 cars vats disables the starter so it wouldn't try to start.
Start simple first. Clean the battery connections and make sure everything is good and tight. Check the ends of your battery cables and make sure they're not corroded also.
06-20-2007, 06:46 AM #4
Question: starting problem
By Faught in forum General HelpReplies: 6Last Post: 10-07-2010, 11:13 AM -
Starting problem.
By Hawk01Eye in forum General HelpReplies: 4Last Post: 04-11-2010, 07:03 PM -
Starting problem
By Da Wookie in forum General HelpReplies: 24Last Post: 07-17-2009, 06:50 PM -
HELP! starting problem
By WS-6 in forum General HelpReplies: 8Last Post: 04-26-2008, 05:05 AM -
Starting Problem !!!!
By ROLLIN1200 in forum GM TrucksReplies: 5Last Post: 09-21-2007, 05:06 PM
