Thread: starting problem
10-06-2010, 04:29 PM #1
starting problem
vid asks all, [ame]http://www.youtube.com/watch?v=41ACTg0llds[/ame]
10-06-2010, 06:10 PM #2
I'm not sure if this would be the starter or the battery going out what are ya'll thoughts?
10-06-2010, 08:03 PM #3Member
- Sep 2010
- WI
- 2000 Trans Am
My first impression is the battery or possibly a bad ground. Check your terminals and make sure theyre nice and clean. Since it is free and simple, I would take my battery to autozone and have them test it. Take a look at the grounding points. Check to see if the cables are frayed or damaged anywhere. Its all free and the first place I would look. Doesnt seem like a starter to me.
If all those look good and your alternator is good(also free testing), It may be a draw somewhere. Im horrible in this area though so good luck.
10-06-2010, 09:36 PM #4
Imho, possibly weak batt or dead/damaged cell.. Possible wire/terminal issue where they are joined.. I'd have the batt load tested aswell..
As for the exhaust, I would try to "oval" the pipe some if it's hitting the top side against the floor pan.. May only need a little bit more of a gap..
Good luck!Last edited by Smittro; 10-06-2010 at 09:39 PM.
10-06-2010, 09:46 PM #5
You could also try pulling the studs out of the terminals and remove the boots. Then a baking soda and water bath for the ends and studs. Then wire brush the ends till shiney. Reconnect.. If that solves the issue pick up some spray gasket tack (permatex, hi-tack) and coat the terminals with a liberal amount of spray.. This will "lock out" moisture and prevent corrosion from re accuring.. Cleans up with normal automotive cleaners like choke, brake etc...
10-07-2010, 07:05 AM #6Senior Member
- Apr 2008
- Madison, WI
Its your battery.
10-07-2010, 11:13 AM #7
yep took it up to oriley's and i had a bad battery thank god it wasn't the starter, its a pain to get to and about 100 bucks more than a new battery.
Starting problem.
By Hawk01Eye in forum General HelpReplies: 4Last Post: 04-11-2010, 07:03 PM -
Starting problem
By Da Wookie in forum General HelpReplies: 24Last Post: 07-17-2009, 06:50 PM -
HELP! starting problem
By WS-6 in forum General HelpReplies: 8Last Post: 04-26-2008, 05:05 AM -
Starting Problem !!!!
By ROLLIN1200 in forum GM TrucksReplies: 5Last Post: 09-21-2007, 05:06 PM -
need help with starting problem
By tds1213 in forum General HelpReplies: 3Last Post: 06-20-2007, 06:46 AM
