Thread: Starting problem.
04-11-2010, 09:30 AM #1Junior Member
- Ontario
White- 98 Firebird Formula
Starting problem.
I hope that I am in the right section.
I've got a 98 Formula with 5.7L
However my problem is when I go to start the car after it is hot.
Has anyone seen a problem where the car takes a while to start on the hot starts?
There is no problems on the cold starts. nor is there a problem if the car is running and I shut it off and start it within ten minutes. But after the ten minute mark the engine has a problem starting. Just rolls over alot before starting and sometimes I get the smell of gas once it starts.
Does anyone have any ideas what could be causing this?
Thanks for your help.
04-11-2010, 11:58 AM #2Senior Member
- Apr 2008
- Madison, WI
It could be alot of things. To me, it sounds like it could be a cam or crank sensor thats on it way out. Do you have any trouble codes stored.?
04-11-2010, 04:48 PM #3Junior Member
- Ontario
04-11-2010, 06:37 PM #4
04-11-2010, 07:03 PM #5Junior Member
- Ontario
Question: starting problem
By Faught in forum General HelpReplies: 6Last Post: 10-07-2010, 11:13 AM -
Starting problem
By Da Wookie in forum General HelpReplies: 24Last Post: 07-17-2009, 06:50 PM -
HELP! starting problem
By WS-6 in forum General HelpReplies: 8Last Post: 04-26-2008, 05:05 AM -
Starting Problem !!!!
By ROLLIN1200 in forum GM TrucksReplies: 5Last Post: 09-21-2007, 05:06 PM -
need help with starting problem
By tds1213 in forum General HelpReplies: 3Last Post: 06-20-2007, 06:46 AM
