Thread: Drill MOD.. now leaking!!!!
09-11-2007, 04:13 PM #1
I did the drill mod to my M6 it all went real smooth. So after I felt the clutch pedal was good I started up the car worked great the pedal had a lot more return than before "great!" so I lowered down my car and I see drip drip drip brake fluid coming out between my engine and trans is it just run off from the bleeder valve going through the bellhousing? or did my slave cyclinder pop? the fluid level it staying good and my pedal still feels good?
any experienced advice with this would be great before I drop the trans
09-17-2007, 03:39 PM #2Impwnded
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
What is the drill mod?
09-17-2007, 05:55 PM #3
Perhaps the hydraulic line just fell off the master where you zip tie it??
09-21-2007, 02:53 PM #4
It very well could be from the bleeder. I really hate were they put the bleeder, I'm going to do a remote bleeder when I do my new clutch set up. If your not loosing fluid it's safe to say its from bleeding it.
05 PBM GTO
Cold Air Inductions CAI,Relocated IAT with omega,Slp Predator tune,Flowmaster axle back with H pipe,Custom tuned TCM.BC Racing coil overs
Sold 01 z28
09-21-2007, 04:50 PM #5
mine made a mess bleeding it. and i did it by my self so its only 90% bled
next time i got it in the air i'll fix it tho
drill mod
By nightcreacher in forum Manual TransmissionReplies: 12Last Post: 06-13-2010, 10:25 AM -
Question: Drill mod
By 99yellowz28 in forum Manual TransmissionReplies: 7Last Post: 09-19-2009, 02:31 PM -
To drill or not to drill, that is the ?
By badblazeSS in forum Manual TransmissionReplies: 1Last Post: 01-16-2009, 02:04 AM -
drill mod
By 9t8z28 in forum DrivetrainReplies: 5Last Post: 11-02-2006, 05:24 PM -
what is the drill mod???
By SLP00blueSS in forum Manual TransmissionReplies: 12Last Post: 09-27-2005, 09:14 PM
