Results 1 to 13 of 13
Thread: drill mod
    Junior Member nightcreacher's Avatar
    Jul 2009
    kent oh
    2000 trans am
    drill mod
    did drill mod,still missing 3rd gear.could i have done the mod wrong?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    What do you mean by "missing" third gear? Missing to me sounds like a driver mod j/k
    Jul 2009
    kent oh
    2000 trans am
    thanks i needed thathttp://www.ls1.com/forums/images/smilies/horse.gif
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    missing 3rd gear sounds like a gate issue .
    Could even be the 3-4 synchronizer assembly.
    Shepherd, Michigan
    98' trans am
    true. wouldnt the syncho assym grind when trying to go into 3rd and not just outright miss ?
    im not manual expert by any means
    Think you're right. OP wasn't too descriptive of the problem so I just threw it out there.
    Is the problem at WOT? Or all the time? Is it shifting from 2-3 only? Can you shift from 4-3?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Bent shifter fork? It's internal. If you did the drill mod and it's still missing, you could:
    a-drop the trans and crack it open to see if there is anything bent inside
    -or-
    b-take the car to a trans shop and have them look at it. You might be looking at a rebuild.
    Jul 2009
    kent oh
    2000 trans am
    drill
    it just does it at wot,and doing a power shift.run it up to 6000 let off gas,gear will go in O K.This is why did the drill mod.Was just wandering why it didn't help the problem
    I'm no expert either, but if it's at WOT only, I am guessing that is a hydraulic issue. maybe air in the line? low/dirty hydraulic fluid?
    Coral Springs, Fl
    Sunset Orange Metalic
    I thought the drill mod was to keep the pedal from sticking. Don't think it would hep you get in gear easier.
    Correct. I believe it opens the line up to allow more fluid in for a smoother clutch pedal and less likelihood of sticking.
  1. DRL drill mod?
    By ldurham in forum Appearance Section
    Last Post: 08-22-2011, 06:45 AM
  2. Drill Mod help
    By Chronic442 in forum Manual Transmission
    Last Post: 05-16-2008, 12:27 PM
  3. Drill MOd
    By SVG210 in forum Manual Transmission
    Last Post: 02-10-2008, 07:01 PM
  4. Drill Mod?
    By Hot Rod SS in forum Manual Transmission
    Last Post: 07-13-2007, 12:37 AM
  5. Drill Mod?
    Last Post: 07-12-2007, 01:59 AM
