Thread: Drill mod
    Member 99yellowz28's Avatar
    akron,oh
    competition yellow
    1999 camaro m6
    Drill mod
    What is the advantage of the drill mod and do you notice a diffrence. I have my tranny out waiting for a clutch and im thinking of doing it. BTW im getting ls7 clutch if it matters
    Alabama
    2002 Trans Am
    Bump
    Bump- I'm in the same situation and was wondering also.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    The drill mod removes the restriction in the hydraulic line so the fluid flows faster. This is supposed to cure the sticky, lazy clutch pedal during quick, high rpm shifts. I'd also like to here some personal stories of people who have done it.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    I did the "drill mod" on my clutch line when I installed my LS7 clutch and new GM master & slave cylinders. Never had a problem with the clutch sticking to the floor or releasing slowly, but I figured I might as well do it while I had the whole system apart. It says to use an 1/8" drill bit, but I ended up using a 7/64" with mine because the 1/8" didn't even fit into the line opening, and I didn't want to chew up the inside of the line.
    akron,oh
    competition yellow
    1999 camaro m6
    is the tick adj master worth getting it also says that the line is bigger so you dont need to do the drill mod
    Junior Member cdorch's Avatar
    Cape Cod
    1998 Z28 M6
    i did exactly what wesman did when i installed my ls7 and all new hydraulics and havent had it stick to the floor or get spongy yet and it did it quite a bit before all the new parts...so to be honest idk if the drill mod did anything because i installed so many other new parts but i figured why not do it, it makes sense
    akron,oh
    competition yellow
    1999 camaro m6
    Quote Originally Posted by cdorch View Post
    Well i got everything on the way from kyspeed $1815 total
    akron,oh
    competition yellow
    1999 camaro m6
    Any other people with drill mod?
  1. DRL drill mod?
    By ldurham in forum Appearance Section
    Last Post: 08-22-2011, 06:45 AM
  2. Drill Mod help
    By Chronic442 in forum Manual Transmission
    Last Post: 05-16-2008, 12:27 PM
  3. Drill MOd
    By SVG210 in forum Manual Transmission
    Last Post: 02-10-2008, 07:01 PM
  4. Drill Mod?
    By Hot Rod SS in forum Manual Transmission
    Last Post: 07-13-2007, 12:37 AM
  5. Drill Mod?
    Last Post: 07-12-2007, 01:59 AM
