Results 1 to 10 of 10
Thread: drilled & slotted rotors?
09-01-2007, 08:20 AM #1
I have to replace the front rotors on my t/a, their warped. So i want to go with cross drilled and slotted but i need advice on which one to go with? Also is all the cracking rumors true, if so should i just get the factory ones for the front, its a dd also
09-01-2007, 08:25 AM #2
the ws6 store has a great deal on them......169.00 for all four
09-01-2007, 09:18 AM #3
Texas-Speed and Thunder Racing are two close places to get them from your location. Relatively inexpensive, get some hawk pads with them as well. Doesn't matter if it's a DD or not, you need to be able to stop pretty quick sometimes...don't take the risk.
09-11-2007, 01:08 PM #4Crazy Canuck !
- Jun 2002
- Montreal, CANADA
drilled and slotted rotors are weaker than plane ones.
They don't offer as much braking power and WAY more prone to warp and crack.
Chose between braking or bling... I'd chose braking and screw the drilling.Eugenio_SS
09-11-2007, 01:55 PM #5
thats what i was afraid of, thanks i will just get the stock ones
09-11-2007, 02:03 PM #6Crazy Canuck !
- Jun 2002
- Montreal, CANADA
brembo blanks are great replacement... and not expensive either.
09-25-2007, 11:10 AM #7
I put on Baer Eradispeed drilled/slotted rotors and Hawk pads about 20k miles ago..no problems and they bite like crazy when warmed up.
09-25-2007, 03:50 PM #8
The Brembo blanks from Tire Rack are good. I wouldn't get drilled because of cracking, warping, and using up your pad quicker. I have 2-piece slotted on my BMW and Cobra.
By the way, StopTech has a great website that can answer most of your brake questions.Last edited by 99 Kobra; 09-25-2007 at 06:50 PM.
'01 BMW 330ci: Race it in a modified class in BMW CCA Club Racing and NASA endurance races.
'04 Lincoln LS V8 Sport: Stock.
'04 Mustang Cobra coupe (white/gray): Modified.
09-25-2007, 05:16 PM #9Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
From what I have been told by the Baer representatives drilled and slotted rotors are more for appearance now then any performance addition. In fact they are supposed to be worse since they have less contact area with the pad (think slick vs treaded tire). I am not sure how much the replacement rotors from Baer are but they make a great product and their reps will treat you well.
09-25-2007, 06:45 PM #10
Question: Slotted & Drilled Rotors.
By trnsman in forum General HelpReplies: 3Last Post: 06-01-2014, 09:03 AM -
Drilled and Slotted Rotors
By GULLETT17 in forum Suspension and HandlingReplies: 37Last Post: 03-05-2008, 11:51 AM -
LS1 drilled and slotted rotors
By rll2 in forum Parts Wanted / TradeReplies: 6Last Post: 01-12-2008, 07:45 AM -
Slotted and Drilled Rotors Directional???
By CWW17 in forum General HelpReplies: 12Last Post: 10-19-2007, 10:33 AM -
Best Slotted and Drilled Rotors
By {FzS}BlacKMagicK in forum General HelpReplies: 55Last Post: 03-21-2007, 09:59 AM
