Thread: Slotted & Drilled Rotors.
05-31-2014, 04:54 AM #1Junior Member
- Apr 2012
- East Hampton Connecticut
pewter- 2002 Pontiac transam
Hello Everyone,
I have a 2002 Trans Am that had a Power Stop brake kit installed on in April of last year. the question I have is that the rear brakes see to be louder now than before when braking at highway speeds. I'm also experiencing a similar sound from the right rear wheel when car is driven at highway speeds with brakes not applied. Also when roads are wet and driven in the rain it seem to be very loud from the rear of vehicle, this started after the brakes were installed. Any ideas?
05-31-2014, 11:14 PM #2
It sounds like your rotor needs to be cut or replace Some times when you buy a after market part it's not perfect or it might be a hair Line bend but I'm no expert I'm just throwing out some ideas for you
06-01-2014, 04:46 AM #3
That's odd. Shouldn't be making any noise. Take the car for a 10 to 15 minute ride and then carefully touch the center area of each back rim. If the wheels are excessively warm, or if you have a distinct brake smell, they are probably dragging. Did you pull the caliper pins to clean and lube them?
06-01-2014, 09:03 AM #411 years of bangin gears
- Jan 2009
- North Jersey
What Jeff said. Also, if you can, scuff the rear rotors with sandpaper to give the rotors a surface the pads can bite into.
Drilled and Slotted Rotors
By GULLETT17 in forum Suspension and HandlingReplies: 37Last Post: 03-05-2008, 11:51 AM -
LS1 drilled and slotted rotors
By rll2 in forum Parts Wanted / TradeReplies: 6Last Post: 01-12-2008, 07:45 AM -
Slotted and Drilled Rotors Directional???
By CWW17 in forum General HelpReplies: 12Last Post: 10-19-2007, 10:33 AM -
drilled & slotted rotors?
By 01ls1ws6 in forum Suspension and HandlingReplies: 9Last Post: 09-25-2007, 06:45 PM -
Best Slotted and Drilled Rotors
By {FzS}BlacKMagicK in forum General HelpReplies: 55Last Post: 03-21-2007, 09:59 AM
