Results 1 to 13 of 13
    Preferred Member CWW17's Avatar
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    Slotted and Drilled Rotors Directional???
    This may sound dumb... but are slotted and drilled rotors directional? Should the lines on the rotors be flowing with the wheel rotation direction or against it?
    Northern Virginia
    BLACK
    They are directional. You want the end of the slot that's closest to the center of the wheel to lead the way when rotating.
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    forward? As in with the wheel?
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    Like this for the drivers side?
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by mbrownin View Post
    incorrect. ebay sellers say so, but if you get any from major companies they go against the rotation of the wheel. the end of the slot farthest from teh beter to lead the way. They look better the other way, but they actually go opposite of how they look like they should. Reason being is that good rotors have directional veins inside and the veins must be curved opposite from the slots for the integrity of the rotor not to be compromised, and the veins HAVE to run a certain direction to properly cool the rotor
    drivers perspective looking forward from the driver's seat
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    okay still confused.... in the picture I posted above, which side should that be?
    Lost in Texas
    Custom Slate Blue
    99 B4C
    passenger. go to any rotor manufacturers site and check out the FAQ, the same question is answered in all of them, it's a common question for sure.
    DFW
    Stg IV a4
    '99 TA Ws777
    I've seen people go either direction, mine are as stated above though.
    Northern Virginia
    BLACK
    Quote Originally Posted by oneBADDz View Post
    That is correct IF the vanes are angled. Lots of rotors don't have angled vanes, so the way I described is better for removing pad dust, etc. from the rotor surface for rotors with straight vanes. But if the vanes are angled, they should take precedence.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    I bought sets of slotted roters from two different manufacturers and neither set had directional veins. Both of them had instructions that said to do it the way I posted. It looks better the way you said, but it is in fact incorrect, I'm not rying to start a war, but every major manufacturer agrees
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Straight from Brembo:
    Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure.
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    The manufacturer of mine told me the internal vanes are not directional so the rotor is not marked and can go either way? I was so confused I had them each way at the same time. Also our front caliper is at the back and our rear caliper is at the front so to contact the pad first wouldn't the driver side rotors each point different from the other?
    Northern Virginia
    BLACK
    Caliper at the front or back makes no difference. Either way, any given spot on the rotor will first contact the pad on the "right" side of the caliper, i.e. if you had a "Camaro" decal on the caliper, the side of the caliper on the "o" end.
  1. Question: Slotted & Drilled Rotors.
    By trnsman in forum General Help
    Last Post: 06-01-2014, 09:03 AM
  2. Drilled and Slotted Rotors
    By GULLETT17 in forum Suspension and Handling
    Last Post: 03-05-2008, 11:51 AM
  3. LS1 drilled and slotted rotors
    By rll2 in forum Parts Wanted / Trade
    Last Post: 01-12-2008, 07:45 AM
  4. drilled & slotted rotors?
    By 01ls1ws6 in forum Suspension and Handling
    Last Post: 09-25-2007, 06:45 PM
  5. Best Slotted and Drilled Rotors
    By {FzS}BlacKMagicK in forum General Help
    Last Post: 03-21-2007, 09:59 AM
