08-27-2007, 03:00 PM #1
HELPPP, o2 sensor wont come off and dont know which one to replace
well first it is seized on and any help on that.
plus my code i threw was PO155 and not sure if that is DRV or PASS side but i do know its behind the cats
please helpp thanks
08-27-2007, 05:31 PM #2
auto zone told me it was the sensor after the cats, and local store told me it was the one in front.
then called again and guy said its bank 2 sen 1
then dealer said there is 3 diff types for years and neede d vin, then gave to me.
but bolt is still not moving
put lots of wd 40 on it and almost broke my healed bone in my arm again, soo gave it quits for tonight
08-27-2007, 05:38 PM #3
its the one in front and on the passenger side good luck with getting it off
08-27-2007, 05:42 PM #4
i really cant believe how stupid these peple making 6 $hr giving car info????
thanks
and any tips casue i sorda tried that front one and seemed like there is noooooo way for a wrench to get in there.
and what would the could be for the PASS rear o2? or it the same #?
08-27-2007, 05:44 PM #5
also to add i pluged in that one to the new o2 sens and still there was a SES light on, and di that do the rear one to. with out screwing in, just being connected. wouldnt that make the code go away???
08-27-2007, 06:33 PM #6
Im pretty sure plugging in the sensors would actualy cause more codes.
If you cant get it loose then i would get the car to op. temp and try again, becareful thou, its gonna be hot.
If you can get the car scanned again and post the code.
Bank 1 sensor 1 = Driver side front, Befor cat
Bank 1 sensor 2= driver side rear, Aft cat
Bank 2 sensor 1= Passenger front
Bank 2 sensor 2= Passenger rear
The sensor needs to be in the exhaust inorder to take a correct reading or you will throw codes. You will also have to reset the computer by either driving it a bit or disconnecting the battery for a while.
08-28-2007, 02:12 PM #7
08-29-2007, 02:22 PM #8Senior Member
- Dec 2006
- Deltona, FL
Sebring Silver Metalic- 2002 Camaro Z28
do you have that funny little socket they make for taking off O2s?
I had the drv side before cat in my way of a motor mount change. I had plenty of room to get a BIG adj wrench in there. I needed at least a 1/2 in drive size wrench to break it free. My adj wrench was longer which allowed me to get plenty of leverage to muster up the torque to get that sucker loose.
It wasn't too tough but enough to make me swear when it broke loose and donated a good chunk of flesh off my fingers.
it wasn't until i was flipping through a tool mag that i saw (and remember) the O2 socket.
I think the hot cat idea is like using a torch on it. But man it is going to be hot as hell though. You can't break it loose cold, you just need to find the right tool.
IAT sensor replace ?
By doberman 152 in forum General HelpReplies: 6Last Post: 05-16-2008, 05:06 AM -
Trying to replace pads but caliper wont come off
By coupe00 in forum General HelpReplies: 30Last Post: 08-15-2007, 01:52 PM -
MAF Sensor, do I need to replace??
By LT1Gun in forum External EngineReplies: 6Last Post: 05-02-2007, 02:41 PM -
MAF Sensor, do I need to replace it.
By LT1Gun in forum External EngineReplies: 3Last Post: 04-30-2007, 08:51 AM -
Knock sensor went bad.. How to replace?
By JehalinTA in forum General HelpReplies: 4Last Post: 03-29-2006, 10:18 AM
