Results 1 to 20 of 31
    STL,MO
    Trying to replace pads but caliper wont come off
    I had the car up on jackstands yesterday and was getting ready to put my new brake pads on but the two bolts on the back side would not come loose, they just kept spinning and going no where and it wasnt stripping the bolt.
    Any ideas?
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    You need to use a wrench to hold the other side.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    I believe you are on the wrong bolts.
    Should be 2 18mm bolts holding the caliper onto the bracket.
    STL,MO
    Thats what I thought too but my dad said they were the ones directly on the caliper
    Aug 1999
    No Where
    Quote Originally Posted by coupe00 View Post
    You need a wrench for the other side. It can spin without one.
    Quote Originally Posted by Ed Blown Vert View Post
    Are the Camaro brakes difference than the Trans Am brakes??
    Aug 1999
    No Where
    They should be the same. There are two bolts that hold the caliper to the bracket. You are talking about the two bolts that hold that bracket to the car.
    I guess I just take the whole bracket off then.
    Don't feel bad, I do the same and think it's the easier way to go personally.
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    NO, they are the same. If you look close when you turn the nut on the caliper, just on the other side there is something turning. If you pay attention you will notice that it is not round, it has two flat spots where you can hold it with a wrench. Its between the bracket and that soft plastic boot that covers the bolt. Oh, and when you tighten them back do the same, hold that thing and tighten the bolt. Other wise you will think it is tight but it will not be.
    San Diego
    2002 T/A
    Thumbs up
    Quote Originally Posted by sandman22 View Post
    +1...
    Dallas, Texas
    2007 CTS-V
    Quick question, I did my brakes not to long ago. I turned the rotors and put new pads on, and now they squeek a hell of a lot more than when they were old. WTF? Is it the pads, if so what is a good pad?
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    what is a good pad?
    Raybestos "Quiet Stop"
    Close to OEM as you can get
    Pep Boys, Auto Zone
    Aug 1999
    No Where
    Stock pads are the best, dust the least. But expensive.
    here
    2001
    dont forget that the e-brake cant be on when doing the rears too
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    Georgia
    2014 Camaro 1LS
    good link
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Yeah, fingered that one out the hard way!! Took me an hour of pounding on the damn rotor before I remembered the e-brake was on.. took it off and pop the rotor cam right off..
    But yeah, I always take the whole braket off too...
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Georgia
    2014 Camaro 1LS
    i turned the caliper bolts for 20 minutes lol......came inside and found a thread that said to use a wrench on the bolt so it wont turn.......102 degrees here with a heat index of 110+.........next side will go much faster......lol also when I got the pads out auto zone have me pads for the front....sucks to be me today
    USA
    BLACK
    Z/28 LS1
    I know how you feel Jesusfan. Here in Florida it has been brutally hot. I went to our community pool last night,which is olympic size and then some, to cool off and the water temperature was 95 degrees! When you looked across the surface of the water you could see a mist of steam coming off it.
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 08:54 PM
  2. Want to replace my rotors and pads.....
    By StrikerWS6 in forum Suspension and Handling
    Last Post: 08-14-2009, 10:33 AM
  3. Question: painted brake pads while painting caliper
    By ggino85 in forum General Help
    Last Post: 03-30-2008, 04:14 PM
  4. Replies: 7
    Last Post: 08-29-2007, 02:22 PM
  5. problem getting caliper loose to change pads
    By Speedy_Gonzales in forum General Help
    Last Post: 08-11-2007, 07:08 PM
