08-11-2007, 09:33 AM #1
problem getting caliper loose to change pads
I have turned them bolts and turned them cant get them out to change pads on the rear. Its been a few years since I changed pads on a car forgot what to do . Any suggestions ?
I had the right bolts. You just have to put a wrench in the middle of the bolt where it has 2 flat spots to keep it from turningLast edited by Speedy_Gonzales; 08-11-2007 at 10:54 AM.
08-11-2007, 09:37 AM #2
Do you have the right bolts. The calapier pads are the ones close together, next to the axle.
99 Z28
U.S. NAVY
P-3 ORION
FLIGHT ENGINEER
***IBNFE***
FLY NAVY
08-11-2007, 09:40 AM #3
08-11-2007, 09:46 AM #42002 Formula Firehawk
- Jul 2005
- San Diego CA
Black- 2002 Formula Firehawk
If the bolts keep turning and turning then you are trying to unbolt the guide bolts. The bolts you need to be taking off are the ones that keep the calipers bolted onto the axle.
08-11-2007, 09:51 AM #5
08-11-2007, 09:53 AM #6
08-11-2007, 09:55 AM #7
08-11-2007, 09:58 AM #82002 Formula Firehawk
- Jul 2005
- San Diego CA
you might be able to unbolt just one of the bolts and loosen the second and just slide the caliper out enough to change the pads. Ive never done it that way, i just take both bolts off and work from there.
08-11-2007, 10:00 AM #9
08-11-2007, 05:14 PM #10
Yes it is posable to remove the guide bolts. After the calapier is removed you most hold the bolt on the inside of the calipier and turn the outside bolt. Only need to do this if you are doing a calipier rebuild. Sounds like you are just changing pads so no need to mess with these bolts. I also take off both bolts to do the pads. Just remember dont hang the calipier by the break line. Could damage the line. Have a box near by to rest it on. Or ballance it on top of the axle.
08-11-2007, 06:28 PM #11
I got it done. After the first wheel the other 3 were a breeze. Kinda nice to have good brakes
08-11-2007, 07:08 PM #12
Need to change ignition tumbler, key getting loose hard to s
By xlor8923 in forum Camaro / SSReplies: 3Last Post: 08-30-2016, 08:35 AM -
How do you change e-brake pads on an 01?
By 5abivt in forum General HelpReplies: 2Last Post: 12-05-2009, 08:09 PM -
Question: painted brake pads while painting caliper
By ggino85 in forum General HelpReplies: 7Last Post: 03-30-2008, 04:14 PM -
Trying to replace pads but caliper wont come off
By coupe00 in forum General HelpReplies: 30Last Post: 08-15-2007, 01:52 PM -
Change Caliper Bleed All Brakes?
By garrity455 in forum Suspension and HandlingReplies: 10Last Post: 05-01-2007, 10:03 AM
