04-30-2007, 05:32 AM #1Junior Member
- Sep 2005
- Upstate NY
Green- 1996 Firebird Formula
MAF Sensor, do I need to replace??
I noticed this weekend when driving around, that when going up a steep hill and getting on it a little bit it feels like it misses/skips every now and then. Now the wires that go to the MAF when idling if you put a small amount of pressure on the wires it will cut the car out for a brief second.
I don't know if when going up a hill the engine is shifting to one side just enough to move these MAF wires to cut it out for a quick miss or not. What's everyone else think???
Any help is appreciated.
Oh yeah its a 95 Z28 LT1 6spd.
04-30-2007, 09:02 PM #2
u can un-plug it and see if it runs better, if so.....u need a new MAF or replace the wires going to the MAF
with the MAF un-plugged the car runs off of a speed density calculation to calculate A/F ratio. at least most cars are like this. idk if LT1 is different.
05-01-2007, 02:05 AM #3
05-01-2007, 02:08 AM #4
05-01-2007, 09:24 PM #5is that just LT1's that will stall when u unplug it? because thats how i usually start to isolate problems on other cars. i dont work on many LT1'sIt will run worse, or stall, and set a trouble code if you unplug the MAF sensor.
Your prob. could be the wire harness, or the MAF.
05-02-2007, 04:56 AM #6Junior Member
- Sep 2005
- Upstate NY
Actually after looking at it a little more closely it looks like one of the wires is loose in the plug that plugs into the MAF. Does anyone know if you can splice in a new plug. I'd splice the one I have but the wire is loose way down inside the plug and wouldn't have enough slack in the wire to resplice. I'll take pics if I get a chance....
05-02-2007, 02:41 PM #7Junior Member
- Jan 2007
- south ga
red- 2001 ss camaro
how many miles the car have?..have you ever put a distributor in it, or plug wires?...the skipping under a load is usually an ignition problem...i know those distributors on a LT1 are bad about moisture. i work on a lot of GM vehicles and i've replaced a few LT1 distibutors..but they are not cheep....expect to pay at least $250.00
Question: Reading trans temp stock sensor vs aftermarket sensor in pan
By senicalj4579 in forum Computer & TuningReplies: 1Last Post: 03-29-2011, 07:41 AM -
IAT sensor replace ?
By doberman 152 in forum General HelpReplies: 6Last Post: 05-16-2008, 05:06 AM -
HELPPP, o2 sensor wont come off and dont know which one to replace
By greatwhiteZ28 in forum General HelpReplies: 7Last Post: 08-29-2007, 02:22 PM -
MAF Sensor, do I need to replace it.
By LT1Gun in forum External EngineReplies: 3Last Post: 04-30-2007, 08:51 AM -
Knock sensor went bad.. How to replace?
By JehalinTA in forum General HelpReplies: 4Last Post: 03-29-2006, 10:18 AM
