    houston
    Navy Blue
    ls1 trans am
    Cool Knock sensor went bad.. How to replace?
    Hey I found out that my SES light was due to a bad knock sensor... any idea where this thing is and how to change it out. Also it is 42 bucks at auto zone... know any cheaper places to buy it. thnaks guys
    Senior Member
    Jacksonville, FL
    Well, it's under the intake manifold - not an easy replacement. Maybe it's a wiring/harness problem? Does the code keep coming on after resetting? What code did you throw? I'd exhaust all other possibilities before pulling the intake.
    Feb 2006
    Alabama
    2001 Z 28
    Yea I just put a motor in my car had same code coming up and to come to find out the plug was not making a good connection repluged it in and solved the issue the plug is on the back of the intake closer to the driver side.
    You Snooze You Looze!!
    houston
    Navy Blue
    ls1 trans am
    Ok well I was washing my engine the day the light came on... So can I reach back there and mess with it or do I have to pull the manifold.... I havent recet it yet... for got exaclty how.. any tips on that? Also how important is this to fix... can I drive on it for a while... and is it possible for me to do it on my own... I do small thingslike brake pads.. plugs... window motor... not too much other than that.. thanks guys
    Senior Member
    Jacksonville, FL
    Washing the engine got something wet. Should be dry by now - first thing I'd do is reset the light and see if it comes back. There are two knock sensors under the intake, look at www.ls1howto.com/index.php?article=5 it's for an intake swap and also has pictures of the sensors/wiring with the intake removed. To reset the PCM turn the key on, don't start car. Pull PCM BATT and PCM IGN fuses in the engine compartment. Wait 5-10 min. Turn ignition off. Replace fuses. As far as driving with the code on look up the DTC at www.gearchatter.com to see how it affects the car with the light on.
  1. knock sensor code with new knock sensors?
    By zaaronz in forum General Help
    Last Post: 02-27-2011, 06:26 AM
  2. will bad knock sensor knock down hp
    Last Post: 10-14-2010, 04:49 PM
  3. Question: Replace One or Both Knock Sensors?
    By lsgunner28 in forum General Help
    Last Post: 04-27-2010, 07:17 AM
  4. replace lifters? 98 knock sensors?
    By jmatt07 in forum Internal Engine
    Last Post: 12-24-2009, 05:42 AM
  5. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 08:28 AM
