Results 1 to 2 of 2
03-25-2007, 09:24 AM #1Junior Member
- May 2006
- Morgantown, PA
Pewter- 99
Knock Sensor/Oil Pressure Sensor Issue
Hi guys,
I threw the rear knock sensor code, and after reviewing tons of posts and articles decided to change it. Well, I was able to get the intake off and slide it to the driver's side so I have access to the sensor. I tried gently removing the connector to the knock sensor, but the plastic partially snapped off. What's the easiest way to get those things off? I tried squeezing on a few different points, and it wouldn't release. What's worse, I had to put the manifold back on so I can drive the car...trying to be careful not to break the oil pressure sensor...and I *$#%& broke it. Everything was bolted back on and I started the car, and the check gauges light came on and my oil pressure was zero.
Can I wait a week or two before replacing the oil pressure sensor? How can I get the knock sensor clip off? I'm worried if it breaks I'll have some plastic around the sensor that will fall into the engine after I remove the sensor.
Any help is appreciated!
04-04-2007, 08:28 AM #2
The plastic won't fall in your engine Use a 7/8 deep socket to take it off. I used pliers and grab both side of the clip and squeezed lightly and lifted up.
LS1 Knock Sensor Issue?
By ironfreak247 in forum General HelpReplies: 12Last Post: 04-18-2015, 10:56 AM -
Help: high oil pressure, knock sensor codes, flat spot in accelera
By Stephen Thiede in forum General HelpReplies: 13Last Post: 11-26-2014, 02:33 PM -
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
00 Z28 Knock sensor issue
By karpetcm in forum Computer & TuningReplies: 2Last Post: 10-29-2008, 06:37 AM -
Help KNOCK SENSOR
By TA421 in forum General HelpReplies: 18Last Post: 09-19-2007, 05:54 AM
