Thread: blinker problem
08-16-2007, 06:16 AM #1
blinker problem
when i use my blinkers they seam to skip a beat.. very strange. they would go constant and then stop and go again. any1 have any ideas?
08-16-2007, 08:49 AM #2
check the bulbs...they might be starting to go...
08-16-2007, 08:50 AM #3Member
- Northern Virginia
BLACK- 2000 Camaro SS
The blinker relay might be going bad.
08-16-2007, 09:57 AM #4
the bulbs should be good.. replaced them recently. where exactly would the blinker relay be located? is that something to do with the fuse?
08-16-2007, 09:16 PM #5Junior Member
- Aug 2007
- Pueblo West
Arctic White- 1999 Pontiac Trans Am WS6
Just did it to mine
I just replaced the blinker relay on my WS6. You have to remove the dashboard underneath the steering wheel. just some screws and a couple of clips. It took me about 1/2 hour to figure out where the relay was. It is clipped to the center console just under the radio. kinda hard to see. If it wasn't raining outside right now, I would run and get a quick picture of where it is. To the right of the steering column left of the stereo right behind where the ashtray sits. Hope this doesn't confuse you.
Pat
08-17-2007, 07:29 AM #6
lol... that sounds like a day of fun.. i was hopin it would be somethin under the hood within reach lol.. if u could please post a picture or two just so i have an idea.. thanx so much
08-17-2007, 03:13 PM #7Babies: 2 Girls, 5 FBods
- Mar 2007
- Rainy, WA
of my F-Bodies- Too tough to pick just 1
A little different than the other blinker thread. Indicators flash when they have the proper amount of current flowing, this is why they don't flash when a bulb is out (you can also make them flash quicker when adding an additional bulb). My guess would definitely be a relay/resistor, unless you have spliced any wires in the harness.
08-17-2007, 05:58 PM #8Junior Member
- Aug 2007
- Pueblo West
location, location, location
First- sorry for the crappy phone pics.
You have to take off the two lower dash panels on the car. (the pic is sideways)
Look to the right of the steering column, just behind the change holder (ashtray etc), it is clipped to the interior
You should see the clip and the wires leading to the flasher relay rught there.
Hope this helps.
Pat
Blinker problem
By Spikito in forum General HelpReplies: 15Last Post: 06-08-2011, 02:25 PM -
Blinker Problem
By BlackTAWS6 in forum Firebird / WS6Replies: 24Last Post: 05-12-2010, 08:57 PM -
blinker problem
By ultra_badass in forum General HelpReplies: 8Last Post: 12-22-2008, 11:00 AM -
Blinker problem
By camarostripes96 in forum LT1Replies: 2Last Post: 09-19-2007, 05:57 PM -
blinker problem
By 98silveraptorhoodws7 in forum General HelpReplies: 2Last Post: 01-06-2007, 04:21 PM
