Results 1 to 16 of 16
Thread: Blinker problem
06-07-2011, 02:10 PM #1James Bond
- Aug 2007
- Texas
Blinker problem
my g/fs blinker works sometimes, and sometimes not. the lever still goes down, or up, defending on left or right. but the bulbs dont blink, and theres no click inside, and i may be wrong, but i think the green dash arrow might not blink either.
this is random, seems to work/not work and 50/50 split.
seems like a relay to me, but i know very little about them.
06-07-2011, 02:15 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Did you check the bulbs first? What I do is I put the 4-ways on and look from front to back to see if any bulb isn't flashing. If I spot a non-flashing bulb, I pull it and pluck it to see if the fillament vibrates around in the bulb excessively. If it does, it's bad.
06-07-2011, 02:17 PM #3James Bond
- Aug 2007
- Texas
ive googled it without much luck, some say its an issue with the hazard switch
06-07-2011, 02:18 PM #4James Bond
- Aug 2007
- Texas
yes...all 4 bulbs work....either everything works, or nothing.
06-07-2011, 02:21 PM #511 years of bangin gears
- Jan 2009
- North Jersey
You could swap the flasher and see if it works. If the issue persists, wiggle the signal stalk to see if the signal on the dash blinks either left or right. The switch in the column could be bad.
06-07-2011, 04:39 PM #6
Have you replaced the flashers? there is 1 for hazards and 1 for regular blinkers.
Both are under the dash down by where your knees would be...there is a GREAT writeup on here i saw recently with very goods pics
06-07-2011, 04:41 PM #7
There you go:
http://www.ls1.com/forums/showthread.php?t=156621
06-08-2011, 05:14 AM #8James Bond
- Aug 2007
- Texas
very nice...but this is on 2002? Alero, not my camaro, lol
06-08-2011, 05:30 AM #9
06-08-2011, 06:06 AM #10
Just hope it's not the turn signal switch in the column.. It's a total PITA to get to, and junk yards are usually reluctant to tear open a good column for one.. The one for my GP and the one for my z34 were $160 bucks new.. Neither one had air bags like the Alero so it should be even more fun to change.. I'd try new lamps and flasher module, after that it's column time..
06-08-2011, 06:11 AM #11
Time to invest in a Chiltons or send it to a shop..
06-08-2011, 06:13 AM #12James Bond
- Aug 2007
- Texas
yeah...i was just thinking about the chilton, lol
06-08-2011, 06:19 AM #13
06-08-2011, 06:37 AM #14James Bond
- Aug 2007
- Texas
i have one for mine....
i could be wrong, but i think i have one for 93-97, and 98-02
06-08-2011, 06:45 AM #15
Nice! Much better than the Hanes.. I have both and like the Chiltons much better, and found sometimes the spec sections of the Hanes either does'nt have all the specs, or has a different spec listed than the Chiltons. Sometimes the Hanes proceedures are off too.. Jumbling or lumping things together from engine to engine. Whereas Chilton tends to give proceedures for each type of engine rather than lumping all engines/cars together under the same proceedures..
06-08-2011, 02:25 PM #1611 years of bangin gears
- Jan 2009
- North Jersey
I have used both Haynes and Chilton. I can't complain about either.
Blinker Problem
By BlackTAWS6 in forum Firebird / WS6Replies: 24Last Post: 05-12-2010, 08:57 PM -
blinker problem
By ultra_badass in forum General HelpReplies: 8Last Post: 12-22-2008, 11:00 AM -
Blinker problem
By camarostripes96 in forum LT1Replies: 2Last Post: 09-19-2007, 05:57 PM -
blinker problem
By 6sw00 in forum Firebird / WS6Replies: 7Last Post: 08-17-2007, 05:58 PM -
blinker problem
By 98silveraptorhoodws7 in forum General HelpReplies: 2Last Post: 01-06-2007, 04:21 PM
