Thread: blinker problem
    Member ultra_badass's Avatar
    Corpus Christi
    navy blue matallic
    2000 WS6 trans am M6
    blinker problem
    About two days ago when ever i turn on my lights my right hand blinker stays on. It still flashes when you make a right hand turn but as soon as you put it back it stays on but it only does it when you have the light on i checked all the light and they seem to be good so I'm at a lost for this any help would be appreciated...thanks thomas
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    maybe your blinker arm (the thing that controls your wipers etc) sorry i cant think of the correct name for it...that and check your fuses.
    could just be low on fluid.......sorry, couldn't resist.
    I would first look at your housing and socket on that side and make sure moisture hasn't gotten in there and created a short. Then start working your way back from there.
    Middle TN
    2000 TransAm
    Its funny mine does similar just instead of staying on it cuts off but the blinker still works
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by TA421 View Post
    Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, factory quality blinker fluid should be changed every 150,000 blinks. Our blinker fluid lasts ten times that. KaleCoAuto high quality synthetic blinker fluid meets the highest DOT standards while not being in the least bit DOT legal! KaleCoAuto blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause. KaleCoAuto blinker fluid will not lose its viscosity even in the most extreme situations. Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car.
    http://kalecoauto.com/index.php?main...&products_id=6
    ok thanks..its a little played out now.
    Shepherd, Michigan
    98' trans am
    reason i dont think its the bulb or socket itself is because one of the bulbs/sockets go out..the light will stay solid just liek you described...but wont actually blink...front or back...so like i said..try your fuse, and if not then i think your blinker arm thingy might be messed up or even your instrument panel
    Junior Member slp1122's Avatar
    Nov 2008
    oc/las vegas
    pewter
    2000 camaro ss
    its the bulb. happened to me, i was checking wires and everything because i thought if the bulb was on, it was fine. but i guess it won't blink if the bulb is bad, it just stays on. so i would try changing it out
    Member SteelmanLS1's Avatar
    LSX, Oklahoma
    2000 WS6 Trans Am M6
    Quote Originally Posted by ultra_badass View Post
    First. Change the bulb and make sure there is no moisture creating a short. Second change the Electronic Flasher under the D/S dash. Third have the Intermittent Wiper Switch changed..
    80% chance number Uno, or Dose will fix it though
    Corpus Christi
    navy blue matallic
    well just for and update i still dont know what it was but its not doing it anymore but thanks for all the ideas guys
  1. Blinker problem
    By Spikito in forum General Help
    Last Post: 06-08-2011, 03:25 PM
  2. Blinker Problem
    By BlackTAWS6 in forum Firebird / WS6
    Last Post: 05-12-2010, 09:57 PM
  3. Blinker problem
    By camarostripes96 in forum LT1
    Last Post: 09-19-2007, 06:57 PM
  4. blinker problem
    By 6sw00 in forum Firebird / WS6
    Last Post: 08-17-2007, 06:58 PM
  5. blinker problem
    By 98silveraptorhoodws7 in forum General Help
    Last Post: 01-06-2007, 05:21 PM
