Results 1 to 3 of 3
Thread: blinker problem
    san diego
    98 ta
    blinker problem
    so my left blinker doesnt work. when i put the blinker to turn left, the tail light turns on but not the front and it just stays on and doesnt flash like it should. all the lights work, i already checked that, when i hit the keyless entry the front light works and comes on. i just changed it today so i know the light is good along with all the other lights. i also checked the fuses and had 2 blown but changed them and still the blinker doesnt work and no more fuses are broken. the right blinker works fine and the running light comes on like it should when i turn the lights on, but still no left blinker. anyone have an idea what could be wrong, or can i swing the car by and have someone look at it?
    thanks
    matt
    Arkansas
    99 Trans Am
    Quote Originally Posted by 98silveraptorhoodws7 View Post
    thanks
    matt
    if you already changed the bulb then I would go with the flasher next.. it is located in the panel under your steering wheel i believe there are like 3 screws and then it pulls out. you will see it clipped to a bracket on the right side kinda behind the radio if I remember correctly.
    san diego
    98 ta
    awsome thanks man, ill have to check that out tomorrow!!
  1. Blinker problem
    By Spikito in forum General Help
    Last Post: 06-08-2011, 02:25 PM
  2. Blinker Problem
    By BlackTAWS6 in forum Firebird / WS6
    Last Post: 05-12-2010, 08:57 PM
  3. blinker problem
    By ultra_badass in forum General Help
    Last Post: 12-22-2008, 11:00 AM
  4. Blinker problem
    By camarostripes96 in forum LT1
    Last Post: 09-19-2007, 05:57 PM
  5. blinker problem
    By 6sw00 in forum Firebird / WS6
    Last Post: 08-17-2007, 05:58 PM
